Home > Technical > Jump leads
Page 2 of 3 <123>
shingwell wrote:
That said, I've actually never heard of a battery explosion, but I'm sure someone will know different!
I had one go while starting a large front loader - very loud bang, bits of battery and acid flung over a thirty yard area. Thank goodness I was standing on the opposite side to the battery. Very scarey!
Quote
Post #70111 7th May 2011 10:46pm
LR90XS2011
in June Land Rover Monthly there is a 5 page artical on jump leads and fitting a permanent supply socket pages 81 onwards, I have seen a Railway locomotive with a battery explosion not a pretty sight DEFENDER 90 TDCI XS,
Post #70124 8th May 2011 8:05am
farmer giles
as someone who REALLY doesn't understand electrics Embarassed can someone recommend where a good earthing point would be to connect the -ve claw on the dead vehicle please?
Post #70657 12th May 2011 1:22pm
WarPig
Holy thread resurrection Shocked
But I would like to know this also.
Post #248971 4th Jul 2013 11:42am
Any bare metal component away from the dead battery and clear of moving parts will do. If the dead vehicle has a (properly-wired and earthed) winch, there is usually a good earth point somewhere on it. Alternatively, if it is accessible, wherever the earthed battery lead on the dead vehicle connects to the chassis, or an engine earth strap.
Post #248986 4th Jul 2013 12:34pm
excossack
Why would you not put the negative jump lead to the dead battery ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #249003 4th Jul 2013 1:19pm
Because following "accepted practice" and earlier posts it is the last connection to be made and therefore there is the risk (indeed probability) of sparking. If for any reason either battery is producing hydrogen gas (as a conventional lead-acid battery will when being charged) there is a significant risk of an explosion.
To avoid this risk, make the last connection well away from either battery and anything flammable.
It really isn't nice when a battery blows up. As noted earlier in the thread I have seen it happen, and it is truly a sobering experience. It isn't just the blast, which is big, it is the rain of sulphuric acid which follows it which can be equally injurious.
Post #249011 4th Jul 2013 1:51pm
WarPig
blackwolf wrote:
injurious.
Great word Thumbs Up
Post #249014 4th Jul 2013 2:26pm
mobilecentre
The Defender struggles for a "good" earthing point, most modern Rolling with laughter cars have a specific point designated for the earth connection for jump starting and to a degree battery charging.
In the absence of this point a good solid piece of metal that the jaws of the crocodile clip will hold on such as a bracket or lifting eye has to suffice.
Or you have to install some points
Post #249507 6th Jul 2013 10:22am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Tim, can these be used on 24V, was think of the wife's Horse Hotel, for when the dozy mare forgets to turn off the isolator and gets a flat battery. I hate jump starting with leads on it...? Putting Dreams on Drives at JLR Solihull..
Post #249989 8th Jul 2013 4:49pm
mobilecentre
Yes they will work on 24V no problem
Post #251103 13th Jul 2013 5:52pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
Just out of curiosity, I have fitted an Anderson connector to my seat box and also to my jump lead so no problem starting someone else, but am I safe using this set up if I should be the one with the flat battery?
Regards Dennis Regards
Dennis.
Post #252300 18th Jul 2013 11:09pm
Yes. Electricity works both ways Thumbs Up Darren
Post #252320 19th Jul 2013 6:42am
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
I studied as an Agricultural Engineering Technician in the late 70's and dead batteries on tractors were common. We were taught NEVER to connect the negative first (on negative earth vehicles) as you could easily create a circuit if you then brushed the positive to another part of the vehicle or cause a spark when you attached the jump lead to the positive battery pole.
You should connect the positive first as it'll connect without a spark then connect the negative.
With a completely dead battery, connecting the negative direct to the starter casing can often reduce power loss from the jump lead circuit and help start the vehicle. it'll work easier on vehicles where the battery is in the engine bay but it's difficult with a Defender though due to the battery location.
Post #252330 19th Jul 2013 8:07am
That's not relevant if connecting via an Anderson, though. With the croc clip ends connected to the 'live' vehicle, plugging in an Anderson is about as safe as it possibly can be. Darren
Post #252331 19th Jul 2013 8:10am
Page 2 of 3 <123>
