Home > Puma (Tdci) > whistle
mees
Netherlands 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
whistle
Hi
I´m new to the forum
I always owned a Range Rover Sport, but now bought a defender 110SW 2011, 2.4 tdci Very Happy
The car has done only 27000 km.
I hear sometimes, after long journeys a kind of a whistle.
I noticed that the seal of the metal pipe (left side of the car), which is coming from the intercooler to the engine is sweating some oil.
can this cause this whistling sound? Is this a common problem?
I read about problems with the turbo inlet manifold, bit that seems to be OK, as I couldn't find soot marks
Post #248006 1st Jul 2013 12:25pm
K9F
Yes definately! If it is sweating oil air is getting out under load! Check too to make sure it isn't chafing against the alternator whilst you're at it! I've just fitted stainless steel pipes with silicone adaptors on mine. My old set of pipes hadn't chaffed against the alternator but on the pulley the other side of the cooler.
Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #248016 1st Jul 2013 1:09pm
mees
thanks K9F Thumbs Up
I will try to replace the seal.
Post #248042 1st Jul 2013 2:31pm
K9F
Just slacken off the jubilee clips reseat the pipe and retighten should hopefully do the trick. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #248082 1st Jul 2013 4:04pm
