![]() | Home > Puma (Tdci) > whistle |
Yes definately! If it is sweating oil air is getting out under load! Check too to make sure it isn't chafing against the alternator whilst you're at it! I've just fitted stainless steel pipes with silicone adaptors on mine. My old set of pipes hadn't chaffed against the alternator but on the pulley the other side of the cooler.
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
mees Member Since: 04 Mar 2011 Location: sdijk Posts: 38 ![]() ![]() ![]() |
thanks K9F
![]() I will try to replace the seal. |
Just slacken off the jubilee clips reseat the pipe and retighten should hopefully do the trick.
