Home > My Defender > What Did You Do In Your Defender Today |
Needed to run two cabled into box under drivers seat from cubby box, I have fitted two aux power sockets. Started off well, sunny and dry. Got drivers seat and panel out then the panel that is under cubby box. Hole drilled for grommet then CRACKLE, BANG, and RAIN. In the space of 5 second I was soaked to the skin.
Now sitting watching it pour down wondering how long it will last. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
23rd Jun 2013 3:04pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
fitted security bolts to my front door hinges and replaced the rusty front mud flap brackets with some nice new ones off the bay DEFENDER 90 TDCI XS,
23rd Jun 2013 7:07pm |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 |
Installed the cables for the roof lights. Managed to get all the cables down the back of the b-pillar and into the battery box with only one hole drilled - and that was to get the cables into the roof... fuse panel and switches being done in the next few weeks 2013 Aintree Green 110 Station Wagon SX
23rd Jun 2013 7:19pm |
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 |
Hit my first thousand kilometres
Click image to enlarge |
23rd Jun 2013 7:55pm |
picked up another Sankey and started to fit reverse camera this will be connected direct to Dezl760
24th Jun 2013 6:42am |
Stevelandy Member Since: 22 Apr 2013 Location: Wiltshire Posts: 15 |
The youth action group field needed mowing , should of used the wife's 90 wheel arches full of horse now
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
24th Jun 2013 6:34pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
fitted my New Daytime running lights and Jate rings & LED side light bulbs ...
.... just got to fit the wiring now! Click image to enlarge Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
24th Jun 2013 8:25pm |
Spent most of the afternoon and evening finishing the wiring for two 12v outlets one is a double USB socket. installed in the cupholder space of my newly recovered cubby box, (thanks Matt) installed a 4 way satellite fuse box to make the job harder if not more practicable when looking for the fuse's.
Standing back for a breather noticed water dripping down from just behind the front nearside wheel (naughty word) up with bonnett checking all hose I could put my hands on, no leaks, but where was the water coming from, gets wife to look from above while I shone light up over from behind inner wing, she marks the spot where she saw the light and I puts my hand down a hole. Turns out to be the drain for the heating intake, I glance to the intake grill and the whole thing is full of water. Next thing on shopping list is a snow cowl to stop water getting in. Next job is to fit CB ariel to the back. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
24th Jun 2013 8:34pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
ARC99, Im sure on the Puma you can cut the end off the rubber drain hose to widen the hole, so it doesnt clog up.
24th Jun 2013 8:42pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5872 |
Today I collected 17 packs of Exquisa QuickStep laminate flooring and then delivered it to my mums. 1999 Defender TD5 110
24th Jun 2013 8:55pm |
Gave mine a bit of tlc, tightened wheel bearing on the front(got to get a replacement as it's starting to get noisy) got the grease gun on all the nipples, bled the power steering needs another go probably since I replaced an O ring on the pump, changed the panhard arm bushes(makes you wonder why we put steering guards on when it comes to working on our motors)
And the biggest treat it had was a fluid level check, gearbox was good, both axles were good but they could do with a change really but the biggest one was over a litre back into the transfer box! At least the gearchanges are smoother now and the wheel wobble has all but gone, it's a little perturbing on how these little warning signs creep up on you and whilst you know you should do something about it you put them off and adjust your driving style to accomodate and the next thing you know another month has passed! |
24th Jun 2013 9:46pm |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 |
Installed a 12v socket in the rear. Took 10 mins - most of which was spent looking for a dropped screw!
24th Jun 2013 10:05pm |
It wasn't clogged up it was the amount of water or should I say rain that fell from the sky yesterday and overnight, my back garden was a duck pond this this morning, the bird and other wild life thought it was anyway. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
24th Jun 2013 10:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6111 |
Finished up the 24k service on the 110 and washed it!
Degreased the engine (especially around the fuel pressure regulator) and awaiting a repair kit for said regulator. Worth taking a punt on £11 vs. £150! |
25th Jun 2013 6:26am |
