![]() | Home > Maintenance & Modifications > Ignition barrel |
millepet Member Since: 01 Apr 2013 Location: Wijnendale Posts: 33 ![]() ![]() ![]() |
you can't get a replacement barrel for the same key. You have to buy a new ignition barrel with corresponding doorbarrels, partnumber CWB 500620 for an ignition barrel with 2 doorbarrels and keys.
Greetings, Peter from Belgium |
Just not long put a remote start switch in a Discovery 1 for a mate that's too tight to buy a new ignition switch, or renumerate for sorting him out on a Sunday night after a weekends camping
Ric Member Since: 03 Nov 2012 Location: South Yorkshire Posts: 209 ![]() ![]() ![]() |
Greetings Peter from Belgium , welcome.
I'm just looking at booking for a Belgium trip for the Grand Prix Also looking forward to a camping trip to Wales soon, how's tricks jwl? its only a car! |
kirk Member Since: 08 Dec 2012 Location: Abu Dhabi, UAE Posts: 28 ![]() ![]() ![]() |
Hi All,
Reviving an older post here. It seems my 2009 defender is suffering from a similar problem...in fact two problems with the same part. (1) ignition key sticks/difficult to turn/hard to remove, and (2) when the ignition key is turned there is only a certain "place" where the starter will engage...just turning the key does not fire the engine. A friend inspected the ignition barrel and found the black wire to be loose, apparently the male terminal at the opposite end of the ignition barrel is damaged. I found a technical service bulletin on the stuck key issue.... Ignition Key Difficult To Rotate / Sticks LTB00414v3. Has anyone experienced a similar problem? Is this a dealer fix or can an independent do it without too much difficulty? Cheers, Kirk |
