Home > Maintenance & Modifications > Ignition barrel
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Ignition barrel
Think my ignition barrel is failing, sometimes it's not springing back when starting and stalling the car.
Is it an easy swap
Can I get one that works with the original key?
Or do I change to a push button start? Cool its only a car!
Post #211786 16th Feb 2013 8:39pm
millepet
Belgium 2009 Defender 110 Puma 2.4 SW Orkney Grey
you can't get a replacement barrel for the same key. You have to buy a new ignition barrel with corresponding doorbarrels, partnumber CWB 500620 for an ignition barrel with 2 doorbarrels and keys.
Greetings, Peter from Belgium
Post #245916 23rd Jun 2013 2:58pm
JWL
Just not long put a remote start switch in a Discovery 1 for a mate that's too tight to buy a new ignition switch, or renumerate for sorting him out on a Sunday night after a weekends camping Rolling Eyes Looks like I'll be busy next time he's in "trouble" Whistle
Post #245924 23rd Jun 2013 3:16pm
Ric
Greetings Peter from Belgium , welcome.
I'm just looking at booking for a Belgium trip for the Grand Prix
Also looking forward to a camping trip to Wales soon, how's tricks jwl? its only a car!
Post #246082 23rd Jun 2013 8:11pm
kirk
United Arab Emirates 2009 Defender 110 Puma 2.4 SW Blenheim Silver
Hi All,
Reviving an older post here. It seems my 2009 defender is suffering from a similar problem...in fact two problems with the same part. (1) ignition key sticks/difficult to turn/hard to remove, and (2) when the ignition key is turned there is only a certain "place" where the starter will engage...just turning the key does not fire the engine.
A friend inspected the ignition barrel and found the black wire to be loose, apparently the male terminal at the opposite end of the ignition barrel is damaged.
I found a technical service bulletin on the stuck key issue.... Ignition Key Difficult To Rotate / Sticks LTB00414v3.
Has anyone experienced a similar problem? Is this a dealer fix or can an independent do it without too much difficulty?
Cheers,
Kirk
Post #277127 27th Oct 2013 10:12am
