Home > Td5 > Diff lock light |
Possibly.....or a dodgy switch. Have you tried engaging and disengaging the difflock to see if the light operates accordingly? If you go through life with your head in the sand....all people will see is an ar5e!!
15th Jun 2013 12:54pm |
Sounds to me like the switch, I had the same problem An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
15th Jun 2013 4:14pm |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
Is the difflock engaging? I sometimes had that when I first bought mine, turned out the difflock wasn't engaging properly. It sorted itself out with use.
15th Jun 2013 6:10pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Just been out in it again, and if I engage the diff lock the light comes on permanently, if I disengage, the light flashes intermittently, so I guess it's the switch? 2008 TDCi 2.4 XS CSW
16th Jun 2013 1:00pm |
If the vehicle has been waxoyled that could be the reason. Try and exercise the switch a few times or clean it off.... If you go through life with your head in the sand....all people will see is an ar5e!!
16th Jun 2013 2:28pm |
