Home > Td5 > Diff lock light
johnnyd
Diff lock light
Hi all
I have just driven my landy through some heavy rain, and the diff lock light is flashing on and off, does that sound like water getting to a switch somewhere?
JD 2008 TDCi 2.4 XS CSW
Post #243808 15th Jun 2013 12:48pm
K9F
Possibly.....or a dodgy switch. Have you tried engaging and disengaging the difflock to see if the light operates accordingly? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #243810 15th Jun 2013 12:54pm
GUM97
Sounds to me like the switch, I had the same problem Confused An engine to TDi for!
Post #243871 15th Jun 2013 4:14pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Is the difflock engaging? I sometimes had that when I first bought mine, turned out the difflock wasn't engaging properly. It sorted itself out with use.
Post #243888 15th Jun 2013 6:10pm
johnnyd
Just been out in it again, and if I engage the diff lock the light comes on permanently, if I disengage, the light flashes intermittently, so I guess it's the switch? 2008 TDCi 2.4 XS CSW
Post #244070 16th Jun 2013 1:00pm
K9F
If the vehicle has been waxoyled that could be the reason. Try and exercise the switch a few times or clean it off.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244085 16th Jun 2013 2:28pm
