Home > Technical > SVX x-tech front end - how do lights work.....
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Seems a silly question but my X-tech has the boggled eyed SVX front end on. I am sure when I first got it and I flashed my headlights the main beam in the headlamp flashed and so did the extra little lights under the indicators.
Last night whilst waiting for the nice man to cook my "home made balti" I checked the lights and couldn't get the little ones to illuminate. I tried flashing the light with everything turned off or on sidelights or on dipped beam as well as putting the headlights on and switching to main beam.
Should they work with all main beam operations (so when main beam is flashed and when lights are on and switched to main beam)?
TIA
Craig 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #243125 13th Jun 2013 5:29am
yes, they are just spot lights - they should come on with the main beam
check the little yellow relay in the battery box, does it click when you put full beam on ?
Post #243129 13th Jun 2013 6:00am
mrandmrsh
Thanks bpman, I checked he relay and all was clicking away. But as I fiddled about old feel something loose behind the relay. The fuse was loose.
All sorted and main beam is much better Smile
Regards
Post #244035 16th Jun 2013 11:13am
Glad I was of help
I'm looking forward to what LED lights Tim has to replace the 90mm's
Post #244037 16th Jun 2013 11:16am
Aren't we all perhaps we should pose the same question next week at the show Rolling with laughter
Post #244068 16th Jun 2013 12:54pm
mrandmrsh
Thanks all - I looked at the fuse and it was clicking away but the fuse was loose. Shoved it back in et voila.
Thanks for the pointer
Post #246892 26th Jun 2013 9:32am
Cheshire110
Don't they have sidelights then? Dim-dip? (The work of the devil) Cheers, David
Post #253935 27th Jul 2013 2:18pm
