![]() | Home > My Defender > My 90 TD5 Build and Upgrades |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
cheers, it's taking time and like you say far more satisfaction in making the mods for it especially wheh they are better built than what you can buy!
![]() 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
has anyone a suggestion where to fit an on board water tank? 2008 110 2.4 XS Utility (Hagrid)
thought i'd post a few updates of what I've been upto lately:
D2 Auto Dimming and Compass Rear View Mirror 2 x Auxillary Fuse Boxes 1 in front 1 in Back both with 6 Ign Live and 6 Perm Live With Earth Bus Bars Twin Rear Fog and Reverse Lights on Back Few Pics Below [URL=] ![]() [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
marsie Member Since: 17 Nov 2011 Location: sheffieldish Posts: 532 ![]() ![]() ![]() |
Like the mirror mod
![]() 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
a few pics of late [URL=]
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
How did you make the cubby box riser? just some lengths of ali box tig'd together?
looks good. |
basically yes
finally got my sound proofing finished and all carpet trimmed too looking good now pics to follow, just need to get all the wiring back in now
Hi All,
after some issues with my TD5 running lumpy I narrowed it down to the in tank pump being fubar. I really didn't want to remove the tank and therefore decided to make an access panel in the floor. Measurements and Pics on how I did it below: standing at the bank of the vehicle measure 330mm from far back edge of rear cross member. then measure 400mm from bottom of left hand side wheel tub centre the 2 measurements and make a square hole 200mm squared I used a angle grinder so I could control the depth of the cut as at the sides there isn't a lot of clearance underneath to the tank about 25-30mm prise the cut out section there will be a rivet holding it to the tub floor support I then cut the support out as this makes it so much easier but I'm sure it could be done left in place if you really wanted Then clean and hoover any loose dust/dirt/crap out from round the pump retaining ring the retaining ring undoes anti clockwise and has notches on it to be able to use a blunt screwdriver etc to help undo it pump is sprung loaded to putting some pressure on the pump will help to undo also I then removed the old pump being careful not to break the pipe retainers as you can't buy these seperateley (only with a new pump or new pipes) once out I gave the aperture a good clean before fitting the new pump replace the retainer clips if you have them then fit the new rubber seal in the top of the aperture place new pump into position with the retaining ring on as difficult to get past the pipes once pump is in push down pump and replace retaining ring (pump is sprung loaded so some downward force is needed. once in and secure refit pipes and lastly the plug once I checked that all was ok I then ran the fuel prime sequence and miracle she started straight up. I then cut a 3mm piece of alloy 230mm square to give 15mm overlap all round I then cut a piece of sound proofing to fit the hole I had cut and fitted to underside of panel I then placed panel over hole and drilled 12 holes equally around then I put some silicone underneath replaced panel and pop riveted in place it now sit exactly flush with the sound proofing and doesn't protrude at all. I will replace the carpet all back to normal ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I hope this helps anyone who needs to do the same thing ![]() 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
nice work
![]() They should have designed an access hatch like that from the beginning .. |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Its strange that they didn`t build it with tank access as earlier 109`s and 110`s had access panels in the rear load bed to allow access to the sender units on rear mounted fuel tanks!
Richalot Member Since: 02 Nov 2013 Location: Norfolk Posts: 37 ![]() ![]() |
What a great work around thanks for sharing it The closer you are to death the more alive you feel
well today I manged to get most of my roof console in including getting the wiring in for cb interior lights etc
I will post some pics up at the weekend 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge A few pics of my roof console now it's finished 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
