Home > Technical > Rear A frame ball joint nut |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Does anyone know the size of and type of spanner required for the A frame ball joint nut on a 110?
Cheers Keith |
13th Jun 2013 9:12pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
They are a pain to get off best option put a complete one on
13th Jun 2013 9:59pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
its still needs to come out though. but yes a complete unit is easier for refit if it is the joint you are looking to change Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Jun 2013 6:18am |
Evsy Member Since: 03 Jul 2013 Location: Carmarthen Posts: 15 |
According to repair my land rover it's a 30mm socket on an extension bar either to ratchet or probably more use, a breaker bar.
10th Sep 2013 2:23pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
30mm socket.
Echo the comments about replacing with a complete fulcrum and OEM quality ball assembly. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Sep 2013 2:34pm |
Thanks folks,
I bought a set of the Stahlwillie sockets off AAronmorris as 'spares' I cut about 5mm off the end of the 30mm socket, then ground a good chamfer around the drive end, now with a long extension bar I can get a good purchase on the nut, I wanted to make sure the taper itself was seated properly before I went further. I still get an annoying clunk sometimes from the back (all super pro bushes fitted) so new joint soon! Keith |
10th Sep 2013 9:37pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Hmmm. Bought some sealey crows feet and the 30mm one is a loose fit and doesn't seem suitable?
Will try again in the light probably at the weekend but it isn't looking promising. Is it defo 30mm not some imperial jobbie? |
17th Sep 2015 8:54pm |
Definitely 30mm 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Sep 2015 11:50pm |
Thank yo!u.
Would seem the 'professional' tools I brought are rubbish then |
18th Sep 2015 4:58am |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
I just ground a slot in the old one, came off no problem! 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
18th Sep 2015 5:56am |
Not wanting to over do it I've managed to loosen all 3 nuts ()
It would appear an old 3/8th worth spanner is a good fit...all the 30mm stuff I tried was a loose fit? Anyhow it's all loose and ready for a swap over when it's light again. Thanks. |
19th Sep 2015 5:39am |
Done
Bolts don't slide out very easily....if I had to do it again i'd allow an hour. If you know which end of a spanner to use perhaps 30mins? |
19th Sep 2015 11:53am |
