Home > Puma (Tdci) > Rear rear 110 seat removal |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 |
Do you mean the handle itself, exactly the same as handle on front seats ?
If so, man up and pull |
8th Jun 2013 1:01pm |
there are a couple of mushroom plugs to remove first, then the cover pulls off
(3rd row) |
8th Jun 2013 1:08pm |
rs2315 Member Since: 16 Sep 2012 Location: yorkshire Posts: 125 |
I've removed the plugs, but I still can't pull the shroud clear because of the plastic lever above the shroud. It's the plastic lever that I need to shift, and it aint playing ball. Any suggestions? rs2315. |
8th Jun 2013 7:42pm |
the plastic cover on the level pulls off
8th Jun 2013 10:15pm |
I've pulled till my eyeballs were popping but no joy. Don't really want to take mould grips to it. Sounds like my plastic cover is the most stubborn LR ever made. Thanks bp for input. I'll ponder tonight for another attack on it tomoz. rs2315. |
8th Jun 2013 10:47pm |
Nice hot hair dryer directed onto cover did the trick. rs2315. |
9th Jun 2013 10:27pm |
well done
10th Jun 2013 7:31am |
