![]() | Home > Puma (Tdci) > Rear rear 110 seat removal |
Do you mean the handle itself, exactly the same as handle on front seats ?
If so, man up and pull ![]() |
there are a couple of mushroom plugs to remove first, then the cover pulls off
(3rd row) |
rs2315 Member Since: 16 Sep 2012 Location: yorkshire Posts: 125 ![]() |
I've removed the plugs, but I still can't pull the shroud clear because of the plastic lever above the shroud. It's the plastic lever that I need to shift, and it aint playing ball. Any suggestions? rs2315. |
the plastic cover on the level pulls off
I've pulled till my eyeballs were popping but no joy. Don't really want to take mould grips to it. Sounds like my plastic cover is the most stubborn LR ever made. ![]() Thanks bp for input. I'll ponder tonight for another attack on it tomoz. rs2315. |
Nice hot hair dryer directed onto cover did the trick. rs2315. |
well done
