Home > Puma (Tdci) > Rear rear 110 seat removal
rs2315
Hi guy's, just require a bit more of your wisdom.
Please tell me how to remove plastic lever cover. This has to come off before I can remove shroud to get to bolts.
I've googled it, and the answer is just pull on it, but to no avail.
Any tricks to this before I get the hacksaw blade on it Rolling Eyes
Now just going to check if plastic lever cover is a seperate part I can order, just in case I need to butcher it.
Thanks for any help.
rs2315.
Post #241955 8th Jun 2013 11:56am
Do you mean the handle itself, exactly the same as handle on front seats ?
If so, man up and pull Mr. Green
Post #241958 8th Jun 2013 12:01pm
there are a couple of mushroom plugs to remove first, then the cover pulls off
(3rd row)
Post #241959 8th Jun 2013 12:08pm
rs2315
(3rd row)
I've removed the plugs, but I still can't pull the shroud clear because of the plastic lever above the shroud.
It's the plastic lever that I need to shift, and it aint playing ball.
Any suggestions?
rs2315.
Post #242035 8th Jun 2013 6:42pm
the plastic cover on the level pulls off
Post #242098 8th Jun 2013 9:15pm
rs2315
I've pulled till my eyeballs were popping but no joy.
Don't really want to take mould grips to it.
Sounds like my plastic cover is the most stubborn LR ever made. Evil or Very Mad
Thanks bp for input.
I'll ponder tonight for another attack on it tomoz.
rs2315.
Post #242111 8th Jun 2013 9:47pm
rs2315
rs2315.
Nice hot hair dryer directed onto cover did the trick.
rs2315.
Post #242380 9th Jun 2013 9:27pm
well done Thumbs Up
Post #242415 10th Jun 2013 6:31am
