![]() | Home > Maintenance & Modifications > Rear Spring Replacement |
I was keen to do this job, but I was daunted by starting it! So I thought I would write-up my findings to help others.
My Defender is a 110 USW, and (for my needs) the rear end is too stiff. Ride is OK when fully loaded, but for the vast majority of the time I don't carry that much gear (kayaks, mountain bikes etc). SWMBO complains about the "choppy ride"... ![]() Thanks to MountainMan ![]()
So I bought some RKB500300 springs from Dan @ Duckworth Parts (Defender2.NET sponsor of course), and they duly arrived as promised 2 days later ![]() The most daunting piece was jacking the rear of the Defender, and then supporting the chassis on axle stands. However it all went quite well. 1. Slightly loosen the rear wheel nuts. 2. I used a trolley jack (under the rear diff) to jack-up the rear till both rear wheels were just off the ground, and then positioned the axle stands on the chassis (with a wooden block for protection) at the lower of the chassis where the rear towing bracket bolts are (just behind the rear anti-roll bar mount). Remove rear wheels before lowering the vehicle onto axle stands. 3. With the rear wheels off, I lowered the vehicle so the chassis (only slightly - the axle stands were touching before I removed the jack from the diff) was supported by the axle stands (leaving the jack as well for additional security). This allows the axle to "hang" on the shock absorbers, with the weight off it. 4. Starting with the passenger side, I used the vehicles own bottle jack to support the axle so that I could remove the upper shock absorber mounting (17mm I believe). 5. With the shock removed, I removed the 2 nuts/bolts on the lower spring seat: This picture shows the upper shock absorber mounting removed, and a spanner on the bolt on the lower spring seat: ![]() Click image to enlarge This picture shows the loosening of the lower spring seat: ![]() Click image to enlarge Note that the bolt (upper) is 13mm, and the nut underneath is 15mm... 6. Once the lower spring mounting is removed, you should feel the spring is a little bit loose in it's housing, but no way you can get it out yet. Other than getting the chassis mounted on axle stands, the next bit is the tricky bit. 7. Using spring compressors, compress the spring by about 2 inches so it can be removed. TIP: Use the standard bottle jack to raise the other side of the axle slightly, it has the effect of "rocking" the side you are working on so the axle is slightly lower by a few mm - makes it a LOT easier (I found out the hard way, when I was doing the 2nd spring ![]() Spring Compressor - borrowed image: ![]() My spring compressor was about £20 delivered off ebay - I bought "US PRO" ones, 370mm ![]() 8. After that you can wiggle the spring out of position. Here's mine (new & old) side-by-side: ![]() Click image to enlarge Whilst apart, I cleaned all the components, and applied a bit more dinitrol to parts I hadn't reached when I treated the chassis last year (such as inside the upper shock housing). 9. Remove the spring compressor from the spring you have just taken off, and put the spring compressor onto the new spring. Tighten the spring compressor to shorten the spring so you can get it seated back to the vehicle. 10. Seat the new spring in the vehicle and remove the spring compressor (if you jacked the opposite side of the axle slightly, the spring will be easy to rotate and position into it's proper position by hand). 11. Re-install the spring lower mounting, and fasten the retainer plate with the 2 nuts & bolts. NOTE: There were 2 washers on each bolt, and they both fitted between the retainer and the lower mounting (i.e. some sort of packing). Torque for spring retainer plate = 45 Nm 12. Use the bottle jack again on the side you are working to level-up the axle so that you can refit the top mounting of the shock absorber. Torque for upper shock absorber mounting = 75 Nm Lower mounting (to axle) 38Nm Double-check everything. 13. Put the wheels back on (I had to raise my trolley jack under the diff slightly to get the wheels on, because the axle sat slightly lower that would allow the wheel to line-up). Wheel nuts slightly tightened at this point. 14. Remove Axle stands, lower vehicle. Alloy Wheel Torque is 130 Nm. Finished ![]() It took 3 hours from start to finish. Like all these things if I did it again it would be much quicker (the 2nd spring was much quicker than the first!). Has it worked? I don't know yet. I'll report back when I've done a few miles. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 10th Sep 2016 11:07am. Edited 1 time in total |
Excellent write up
![]() Last edited by Go Beyond on 30th May 2012 2:04pm. Edited 1 time in total |
Springs are RRP £63 (ish) each for genuine Land Rover. But you had better check yours - they should already be CSW springs in which case you'll need something else, I know szracer on the Forum had some from Extreme 4x4 which are softer than CSW ones... Pattern Parts (i.e. Britpart etc) are available for around £43 (each) on the web (try googling the part numbers given above). Dan at Duckworths gave me a Forum Discount (give him a PM or call) on genuine parts. I wanted LR Original because my Defender is still in Warranty (and I don't want any modifications to be obvious to a dealer in case they try & wiggle out of a warranty claim in the next 2 years ![]() Last edited by MartinK on 30th May 2012 2:22pm. Edited 1 time in total |
When researching the job, I found a youtube video of someone doing this in a "remote place" - he basically jumped up and down on the hub/axle (with shock disconnected, and on a high-lift jack IIRC) whilst his mate wrestled with the spring - they did manage it. ...but I'm a bit more risk averse ![]() |
It's definately easier with the right tools ![]() Although it's amazing how easy it is for a spring to 'fall out' whilst offroading when you don't want it to !!! |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Thanks for the advise Martin, ![]() |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
As said, with a bit of knowledge you can easily remove springs without compressors.
I've always managed to just step on the hub and push axle down far enough to simply pull spring out, both front and rear ... and i've done many a set ![]() |
DMAKX Member Since: 18 Nov 2010 Location: In The Middle Posts: 47 ![]() ![]() ![]() |
Martin, great write up. I'm with you, much easier to have the right tools for the job
![]() Would love to know if you think its been worthwhile once you've had a chance to test it out properly. Whilst the USW is a great improvement in ride comfort over my last 90, I do find it a bit choppy, especially when getting low on fuel. I don't normally carry much weight in the back but do find that adding a trailer just makes it that much smoother. DMAKX |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Stickied as requested
ARMYBOB Member Since: 16 May 2009 Location: north luffenham, rutland Posts: 81 ![]() ![]() ![]() |
we did mine yesterday, the springs did not need compressing, to get off, just undid the retainers, jacked the body up (used a high lift carfefully) it gave just enough to wriggle the spring out and put the new one in
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hi,
thanks for comments, interesting unfortunally, I have also the purple/brown spring one question before I change them, if I take of the anti roll bare, would it be not better ? (I am driving land for more than 35 years and never had anti roll bar ) thanks for the answer Philippe def 110 SW 5 places and 3000 km current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
As stated earlier, spring compressors really aren't required unless working of seriously extended springs.
The way I have always done it has been foolproof and simple. Jack up vehicle and support the chassis on axle stands. Remove both wheels from the axle being worked on. Remove shock at one end (or completely if shock is being replaced at the same time). Lower the axle on the jack always keeping an eye on the brake-lines. When the axle has dropped the spring can be manouvered out fully extended. Fitting the new spring is the reverse proceedure. Do the same at the other end of the axle. Worst case scenario is that the bushes will prevent the axle dropping far enough if longer springs have been or are being fitted. To overcome that just push down on the axle while the spring is being unseated and manouvered out of position. I don't have anti-roll bars fitted so I guess they may need to be released first to allow full axle movement? ONE LIFE, GET IT! |
Tarrel Member Since: 21 Sep 2012 Location: Ross-shire, Scotland Posts: 94 ![]() ![]() ![]() |
So, all things considered, did it improve the ride-comfort? I have a Utility Wagon which i normally drive quite lightly laden. The hard ride is driving me up the wall! 2012 Defender Utility Wagon
1981 SIII 88 inch SW Follow our blog: www.newlifeinnorthernscotland.blogspot.co.uk |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
@tarrel
from my own experience driving mainly with light loads: 1. I use standard [not HD] LR road springs 2. Koni shocks 3. run front at 28psi and rear at 35 for my 90 as 38 was too hard sum of the above gives me a good ride. I also have a stiffer rear ARB to aid with reducing roll. BM52 |
