Home > In Car Electronics > Head unit recommendation
Page 1 of 3 123>
Innuendomaster
Having trawled through many long threads on this, I have a couple of questions. From what I've read am I ok to assume that its a simple remove the OEM Head Unit stand Plug in the New Unit with No wiring alterations?
Also, my search for a decent Head Unit replacement is a minefield of Information. My requirement is Bluetooth/Make and Receive Calls/Pre Outs for Amp
I intend to use the void behind the rear seats of my DC to install and amp/sub and 2 6x9's.
Post #238952 27th May 2013 1:55pm
On the 2.4 it's a simple swap over of HU. The 2.2 it has been altered to a more difficult design to change over. Rolling Eyes
How much total are you looking to spend? No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #238954 27th May 2013 2:20pm
Innuendomaster
Price I wouldn't remotely know, I didn't think I'd need to Amp my ride again since my early driving years. As said, I was considering a hands free kit but only just found that you can get HU's with this incorporated. I definately want Aux in and definately Preouts
What's out there that others have used covering my spec requirement
Post #238962 27th May 2013 2:52pm
Plenty available I shall have a look for you later if you'd like? Regarding BT that is easily possible however most HU that have BT built in are 2 DIN bar a few exceptions which would mean you'd need a new custom bought / made dash to fit a 2 DIN HU into.
Single DIN HU I would go for if I was you with BT added on (Only a small unit) that way you get great functionality without super high prices. And despite what some may say the add on units are not difficult to fit nor do they get in the way. Maybe if it was a Ferrari but in even a 90 there is plenty of room. Pre outs and aux in depends on the actual unit but is all in the details of each unit and it's capability's. Price range will likely be between £150 & £350 for the HU & BT.
Amp and 6x9 wise is another subject again. No Guts, No Glory.
Post #238968 27th May 2013 3:10pm
Innuendomaster
Many thanks for you're info, plenty of more research to be had. I've seen a couple of Single DIN units in Halfords that are Bluetooth to receive and make calls, didn't say anything about extra hidden boxes
Post #238971 27th May 2013 3:12pm
RobKeay
2.2 was a shraight swap when I fitted my Parrott head unit.
Post #238972 27th May 2013 3:14pm
Innuendomaster
Ah, question on you're Parrot unit. I'm guessing its Bluetooth and Handsfree?, how many Pre outs does it have. I need 2 plus a separate Sub Preouts
Post #238973 27th May 2013 3:17pm
RobKeay
Going of memory but sure there are 2 outs and and sub out. I have a sub out but the speakers are just standard at the minute. Think when I get my next 90 ill spend a bit more time on the sound system and sound proofing.
Post #238975 27th May 2013 3:45pm
RobKeay
My Parrott has been working great. But I've never updated it. I have heard a lot of people on here moaning about them and even sending them back. Mines never let me down and use the Bluetooth everyday to make true hands free calls. You just say the name you want and it dials. I also use the Bluetooth to listen to all the music I have on my phone.
Radio reception is good to.
Post #238981 27th May 2013 3:48pm
It may have been this year / only some models affected. There was a user on here that had an issue with the 2.2 that didn't have ISO plugs as standard not long ago. No Guts, No Glory.
Post #238982 27th May 2013 3:49pm
A possible 2 DIN option: Kenwood DDX3023 Multimedia Centre
Medium price range at £200 odd bearing in mind a 2DIN dash costs around the same!
A single DIN option:
Kenwood KVT526 & BT300
I think the above would be the most suitable option for you a straight swap all the features you want and more presides.
This is used:
KVT-526 Used
But maybe worth a pop providing it doesn't go up in price much. Also check every item is included. No Guts, No Glory.
Post #238984 27th May 2013 3:57pm
Innuendomaster
Thanks for those, interesting items. Do all the Phone connectivity HU's have the pop out screens?
Post #238993 27th May 2013 4:18pm
Confused Steve on that mine was the same Thumbs Up
Post #239002 27th May 2013 4:48pm
As far as I know they are all either 2 DIN or Single DIN flip out (like mine see gallery) There may also be single DIN with faceplate 2" style display also. If you search 'Kenwood BT compatibility list' on Google they have a proper set up where you can check what HU works with what phone and BT system. No Guts, No Glory.
Post #239011 27th May 2013 5:22pm
Green Machine
Kenwood have quite a few single DIN bluetooth receivers - clicky linky thingy
I've got one of these - but I still haven't fitted it yet! (After 6 months!) - clicky linky thingy 2005 Td5 | 90 Station Wagon | Tonga Green
Post #239015 27th May 2013 5:29pm
Page 1 of 3 123>
