Home > Puma (Tdci) > Audio system |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
There's a few threads on this. The most common upgrades are larger speakers and a subwoofer. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
5th Feb 2010 8:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20573 |
i have a kenwood dvd system with allstandard speakers n sub ect good enough for me
7th Feb 2010 12:42pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
How loud do people need to play radio 4 for godsakes Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2010 12:55pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
Std quality is really bad! It is not the radio/cd. I fitted some Pioneer speakers on the front doors and improved quite a lot. Puma 110" SW
7th Feb 2010 1:38pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Its not how loud (unless your dell boy ) the standard system has no depth at all Spent a while and I have it right for me |
7th Feb 2010 2:22pm |
Dell boy, is he still alive, haven't heard from him for a while. What have you put in audio wise ken, (tongue in cheek re radio 4 honest) I know what you mean about depth. Original Member Pie n Pea Club.
110 HCPU Tipper |
7th Feb 2010 2:51pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
as an aside, do any of you get a popping noise through the speakers when the AF searches for a stronger signal - alsmos souds like a loose connection or bad arial earth.
7th Feb 2010 5:23pm |
Mr.Boots Member Since: 04 Feb 2010 Location: Wicklow Posts: 15 |
Im gonna get some good rear speakers in Halfords that will fit in the original space, ill see how that goes but will probably end up with an active amp also.
Also need to upgrade the standard land rover head unit eventually....its not too bad though. |
7th Feb 2010 5:47pm |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 300 |
Try listening to the Archers with the aircon on and the fan on level 2 or worse still level 3 , in an effort to stop the car fogging up with 2 wet dogs in the back. Haven't got a clue what's happened this winter. And as for Desert Island discs...well every time its on it features people from both sides of the coin if you get me drift... |
7th Feb 2010 10:55pm |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 |
I replaced the Speakers in my SVX, with Pioneer Two way units (same 4" size).
I also upgraded the headunit to an Alpine iDA-X305 and that with the AUDYSSEY system (Alpine IMPRINT) has given me much better, and balanced, sound quality. |
9th Feb 2010 1:16am |
9th Feb 2010 1:43am |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
Good choice draymond, my iDA-X305 arrived today
I'm looking to have a go at fitting mine on the weekend, the main question that springs to mind is - is there somewhere obvious that everybody has their iPod connector exiting from behind the dash? Peter 2008 SWB Truck Cab 1952 80" Soft top |
9th Feb 2010 8:48pm |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
in the cubby hole where your ignition is is quite a good one, then get a bit of velcro and stick your iPod onto the large vertical piece of plastic to the right of the heater / stereo 110 Tdci Double Cab
9th Feb 2010 10:11pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Run the cable under the carpet from the center console up into the cubby box if you have one You cannot teach stupid people to do clever things
9th Feb 2010 10:28pm |
