Home > Puma (Tdci) > Audio system |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
I might try routing mine down to the cubby box, neat idea! 110 Tdci Double Cab
10th Feb 2010 5:10pm |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 510 |
Would you adam and eve it, just had a quote for the same radio, will be putting my iPod touch on the left hand side of the dash clipping a Brodit mount to it. www.mountonus.com Cogito ergo sum |
10th Feb 2010 5:36pm |
Peter, have you decided yet on where to fit your iPod, was going to attach mine on the left hand side of the dash with a brodit mount but I'm having second thoughts, is the iPod connection cable from the Alpine long enough to fit in the cubby box. Cogito ergo sum |
14th Feb 2010 6:53pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Hi Paul, ive replaced my headunit with an Alpine and the cable is long enough, i just wanted it out of the way of prying eyes, therefore the cubby box seamed the best solution, i have a Mobile storage cubby that allows you to channel the cable underneath and up into the dash You cannot teach stupid people to do clever things
14th Feb 2010 7:03pm |
Thanks for the info discocuzzy Cogito ergo sum
14th Feb 2010 7:06pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
Hi Paul, I ended up putting it in the cubby box too. This works nicely in that the iPod is hidden out of view (as you don't need to touch it with the Alpine unit controlling it) and also it was the easiest option just to route the iPod cable through the gap at the bottom of the dashboard and then straight under the rubber mat (carpet if you've got a posh one). Peter 2008 SWB Truck Cab 1952 80" Soft top |
14th Feb 2010 7:50pm |
Cheers Peter, Cogito ergo sum
14th Feb 2010 8:41pm |
