Home > Maintenance & Modifications > hand brake
Page 1 of 4 1234>
Caterham
hand brake
hi.
couple of questions really -
is it unusuall that sometimes apply the hand brake seems to require less movement and force compared to othertimes
and where / how do you adjust the hand brake. I'm tempted to slacken it right off for trial purposes?
many thanks.
Post #236600 18th May 2013 3:25pm
ibexman
Under the car where it comes through the seatbox
Post #236608 18th May 2013 4:14pm
jst
1st place to adjust is on the drum, large nut at base, then ^^ seat base. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #236669 18th May 2013 7:56pm
JWL
17mm socket and ratchet. Just so you know what you need before you get underneath, it gets tiresome trying to guess the size and crawling out for a bigger socket. Use a 1/2" socket and Censored , fits in quite tidy.
Post #236739 18th May 2013 11:27pm
Caterham
thank you guys.
read the first few posts then found time to crawl underneat before reading the rest (been away and busy).
anyhow this is what I did;
went straight for the seat box adjuster found this a little difficult to adjust (it was like a spring.....turned it then sprung back?)
kept at it and after a bit I reckon I ended up losening it by about 1/2 - 1 turn. hasn't made a significant difference to the hand brake lever feel but the rumbling when slowing down seems to have subsided Thumbs Up
I'm very tempted to have a look at removing propshaft and drum just to give is a clean inside and check theres nothing amiss.
thanks again.
Post #241406 6th Jun 2013 10:17am
jst
Caterham wrote:
thank you guys.
went straight for the seat box adjuster found this a little difficult to adjust .
??? Shocked
its easier to put a socket on the bolt on the fwd facing edge of the drum and just turn that. each to their own. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #241419 6th Jun 2013 11:37am
Caterham
didn't realise at the time there was an adjuster on the drum......
I'll be having another look tho !
Thumbs Up
thanks.
Post #241425 6th Jun 2013 12:28pm
Caterham
was looking last night for an adjuster on the drum....couldn't find anything.
just this post again and there's a nut on the front face..?
didn't notice anything?? must go have another look?
Post #241886 8th Jun 2013 8:20am
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Here is the page from the service manual
The nut for adjusting is labeled "3"
Hope it helps.
Post #241903 8th Jun 2013 9:14am
Caterham
Embarassed
DO NOT USE CABLE ADJUSTMENT..... Whistle
found the nut ! not sure how I missed it before - guess I was assuming there'd be an adjustment on the cable - a bit like the sierra clutch cables.
so now to start messing (adjusting) this nut....
wish me luck. Very Happy
thanks very much Rakthi - most helpful. Thumbs Up
Post #241930 8th Jun 2013 11:24am
Caterham
guys.
a bit of advise please.
having had a go at adjusting the handbrake as per above it would appear that depending on the position of the drum can be either 3 or 4 notches on the handbrake lever to engage the brake. this I can only assume is the result of the drum not being round (which apparently isn't uncommon).
I presume this is something that should be rectified underwarranty ?
I'm sure if I take it back to local LR they'll just tighten the drum up such that the brake does operates on 3 notches - great huh?
NO - not great cos then all the other problems will return (noisey, transmission slowing when changing gear etc)
has anyone had this problem and what was done to resolve it. hopefully just a new drum. I suspect its just a case of a new drum but I'm a little sceptical having had a fail xbox input shaft and replace gbox. I deperately want to bottom things out before the warranty is up.
outside of warranty I wouldn't be too upset having to replace the drum but not so another gear box.
Big Cry Mad
Post #243862 15th Jun 2013 4:55pm
I'd imagine the drum could be put slightly out of true by the handbrake being rammed on too hard. Ideal time for this would be say if an MOT has been completed and they park it outside. I've had it. Rolling Eyes Get out to take it home and it's like the worlds strongest man has put the handbrake on! Shocked WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #243863 15th Jun 2013 5:00pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Caterham wrote:
.......having had a fail xbox input shaft.......
um, what's an xbox input shaft............ Shocked
has Microsoft been involved in Defender design and manufacture now. Do we get a free Service Pack 1 Question BM52
Post #243865 15th Jun 2013 5:09pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Just drive the friggin thing..............please Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #243868 15th Jun 2013 5:12pm
Caterham
xbox......sorry - transferbox.
Willy. I'm driving plenty now and the last few weeks (perhaps more) its been getting better and better.
I have to say I've got a big grin on my face nearly all the time. it actually feels like a modern vehicle and no doubt how it should always have been.
my only concern now is if there's a problem with the hand brake I'd clearly like to get it resolved under warranty and before I start upgrading and giving LR an excuse to void the last few months of warranty (albeit they've agreed to extend the warranty due to all the previous probs.).
Post #243932 15th Jun 2013 10:35pm
Page 1 of 4 1234>
