Home > Maintenance & Modifications > hand brake
Page 4 of 4 <1234
Happyoldgit
...just when I thought it couldn't get any worse..... Shocked
Wayne don't take anything off, just drive the vehicle a couple of miles then feel the drum, if the shoes [not pads] are rubbing the drum will be hot and you are likely to be able to smell hot brake linings. Steve.
http://forums.lr4x4.com
Post #382051 26th Dec 2014 5:18pm
Caterham
Shocked
The prop is now half off but snow has halted progress....might as well take apart and at least have a look inside drum as put it back together will keep you posted.
Hope you are all having a great break from the norm.
Thumbs Up
Post #382097 26th Dec 2014 7:24pm
martinfiattech
If you intend on striping the brakes to see if there is any binding, why not apply some chalk to the shoes rebuild. Drive and strip to re inspect. Any heavy witness marks would indicate a high spot ( along with excessive heat coming from the drum).
My self I would set the brakes according to the manual. Check for bind. Road test 10 to 15 miles, if the drums still cold. It`s fine no further action required.
If your really worried the quickest way to do it is, as we do at work on trucks and trailers. Inspect and set brakes correctly, ensure all pivots, actuators are ok. Road test, get the infra red thermometer out and read off all brakes / axles.
Dead quick and easy.
You can pick up a infra red thermometer for about 70 quid they have loads of uses... Excuse the spelling I`am better with spanners and wires.
Post #382284 27th Dec 2014 1:48pm
Caterham
Thank you.
Now done what I should have done a long time ago - new drum fitted and while setting it up against the original it would appear the original wasn't as round as it should have been Sad
Just need to get the rear prop on and check it all out. Will get it sorted in an hour or two once the children are in bed.
Post #382458 27th Dec 2014 10:01pm
Caterham
Steve......drove home last night without rear prop following fitting of new drum and transmission felt all slack (put it down to no rear prop)
Fitted rear prop last night and went for a drive this am and still slack (real struggle to a smooth gear change -high gears possible but difficult) ..... pulled onto island and it dropped into neutral on t.box.
I wonder if the linkage rod needs extending or shortening?
Anyhow after I can say things are mu he'd improved - the vibration at c 52 mph has gone for starters....will see how things go over the next few days.
Post #382610 28th Dec 2014 1:19pm
munch90
take it the diff lock works ok , if you have drove it without rear prop ?
not that uncommon if you have moved t/box lever to jump out after , best to move lever drive few feet then try moving again same way
Post #382653 28th Dec 2014 4:04pm
mk1collector
If vibration has gone with the rear prop removed could it be rear prop uj's on their way out
Post #382659 28th Dec 2014 4:22pm
Caterham
Just back from the lake district......
Not convinced all is good but that some improvements noted. The vibrating at c52mph I'm sure has gone.
There's a drunk sound from the rear but not a constant pitch it's a wo wo wo not a woooo if that makes sense?
The rear prop uj's seem ok but I do wonder if the prop isn't well balanced? Or if it's simply the rear diff or even the tyres (would be nice to get it quieter but it doesn't worry me).
The issue Steve mentioned rear the hi/lo and the inability to make a smooth gear change came back after 150 miles of motorway to the point where I felt like ditching the motor Sad ...
Unfortunately having the family with pulling over to check if the hand brake was hot or not wasn't really an option so I can't understand what might have caused it?
Also driving home for the most part was fine but at c52mph there seemed to be ex excessive injector knock on light throttle?
(is my memory so bad that it's always that loud but I keep forgetting?
Anyway it got me up and over hard knock pass with only 1 wheel spin and two lots of hand brake flashing Smile
Happy New Year All.
Wayne
Post #383748 31st Dec 2014 9:44pm
munch90
the wo wo wo noise could be tyres , if not directional you could try reversing them
osf to nsr
nsr to osf etc
Post #383815 1st Jan 2015 9:52am
Caterham
Been meaning to swap the tyres over for ages....must pull my finger out and get it sorted.....
Sounds like a new jack and axle stands on the shopping list.
Thank you.
Post #383890 1st Jan 2015 2:11pm
Page 4 of 4 <1234
