Home > Td5 > Td5 issues
adseybear
Canada
Td5 issues
I’ve struggled for a while for anyone to be able to put their finger on what my issue might be.
In short, I have a 2003 Defender 90 CSW, with a safari snorkel and mt’s. It has had the EGR removed and otherwise is completely stock.
It now has 116k miles on it, I purchased it with 40k. I’ve noticed for a while now, that strangely on some days it seems down on power. Whilst not highly scientific, I travel quite a long dual carriageway route every day, and on the same quite steep hill, it will sit at 75 some days, others drop to 70. Im sure even once it wanted to accelerate at 75...
Some days when im in a hurry (on a private road of course) she wont really want to get passed 80, yet others she sits comfortably at 85.
I notice it on the days it seems to be running well as it just seems to rev much smoother up to the top end. Add in that sometimes it'll knock slightly on idle.
I accept that fitting mt’s would’ve dropped fuel economy, but even being relatively careful, most of the time I’m struggling to achieve 24mpg, yet on days where I’ve done a lot of driving and she seems to be running better, I’ve filled up and got 26+mpg.
Any ideas?
Diagnostics havent shown anything, had a new MAF recently and cleaned the intake sensor 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #234334 10th May 2013 10:07am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
I'm watching this as seem to suffer similar issues, sometimes a thoroughbred, sometimes a cart horse...
Post #234336 10th May 2013 10:11am
Laurie
It's been very windy lately.
Have you taken wind direction into account?
This is no joke, it really does make a difference.
Post #234337 10th May 2013 10:16am
mk1collector
I wonder if air pressure makes a difference as at altitude it makes a massive difference to performance. It may be worth Making a note of the weather conditions on the days you notice a difference or having a barometer in the car?
Post #234342 10th May 2013 11:28am
Laurie
Altitude shouldn't make a difference to a turbo.
Seriously affects normally aspirated diesels.
Post #234343 10th May 2013 11:33am
mk1collector
I meant the air pressure at altitude
Edit: just reread your comment and didn't realise there would be a difference with being a turbo'ed engine
Post #234345 10th May 2013 11:35am
barbel jim
Humidity will make a difference, as altitude due to the denseness of the air, but the effects I would have thought would be negligible and unnoticeable on standard engine.
I would check all the turbo pipe work. Whistle I had something similar a few years ago, which turned out to be a busted jubaliee clip on the intercooler Thumbs Up
Have you checked for a sticking wastegate, oil in the loom ??
Post #234350 10th May 2013 11:45am
adseybear
Canada
no oil in the loom,
and I totally understand your point laurie and do notice wind playing a part at higher speeds, but doesnt explain it not running as smoothly. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #234369 10th May 2013 1:06pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Td5 issues
I had a similar issue and I change the radiator and hoses and now the power is back, I believe that the problem was that the radiator was clogged and the temperature rise making the engine less efficient, I measure it with my Nanocom (before it broke) and it use to go up to 105C now it hardly goes more than 85C. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #234377 10th May 2013 1:45pm
Air flow meter on its way out?
On days that it doesn't drive well, try unplugging it and see if the power "reappears"
Post #234378 10th May 2013 1:54pm
adseybear
Canada
had a new radiator and intercooler a year ago (had a bit of an oopsie with an oncoming d2) Whistle
recently had a new MAF too. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #234380 10th May 2013 2:04pm
Since the problem occured? sometimes new MAF's can go duff.
Post #234383 10th May 2013 2:19pm
adseybear
Canada
Yeh, its definately not MAF related 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #234384 10th May 2013 2:25pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Mine is very similar never that noticeable in terms of lack of speed but some days just seems to have a few more bhp than another. I actually put it down to weather and air temps/ air pressure. Mine has 46k on the clock, new injector loom, well serviced. Never actually seen what it drives like with maf disconnected. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #234395 10th May 2013 3:41pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Mine is the same. Safari snorkel etc.. Done all the usual suspects. Can be dangerously slow at pulling out in traffic-then goes like a flying machine????
Post #234409 10th May 2013 5:16pm
