![]() | Home > Technical > Engine and/or transmission vibration |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Is this when the engine is under no load ?
Like when you are at a constant speed not accelerating and not decelerating. Regards Pete |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Yes that's right Pete, its at around 1900revs 4/5/6th gears at a constant speed without accelerating so around 40/50/60 mph depending on gear. It's just been into Land Rover to have some swivel seals replaced and they said they couldnt find anything wrong with the engine. |
I may be wrong but from the experience i have had on this engine and the transit van its self tome it sounds like the EGR actuation problem which at the moment is been addresed by Ford and i hope soon landrover.
Regards pete |
Pete, I had one of the EGR blanking plates fitted to my 300 Defender before this and it definitely improved things. Does fitting an EGR blanking plate = a healthier engine with no detrimental effects? PS where can I find the EGR on this engine? Last edited by mrwoo on 6th Jun 2008 5:12pm. Edited 1 time in total |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Im just going through a dealer "theres nothing wrong" syndrome ![]() |
