Home > Technical > Engine and/or transmission vibration
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I'm just writing to see if anybody else has experienced this problem and may know if there is actually a problem or not.
My Defender (puma) has now covered just under 20k without any issues at all. But now, I am experiencing what can only be described as a much louder engine noise/vibration at around 1900rpm's in all gears. The noise/vibration is more noticeable in 5th and 6th with there being extra load on the engine. I cannot work out whether the cause is actually transmission or engine related but the engine does sound noticeably louder and not as smooth as it used to be before I noticed the change.
Does anybody know if this is a problem?
PS I did think it may have been the EGR valve sticking but there is no black smoke whatsoever which from reading is a typical symptom of that problem
Many Thanks Rich Rolling Eyes
Post #2294 3rd Jun 2008 8:03am
bell-auto-services
Is this when the engine is under no load ?
Like when you are at a constant speed not accelerating and not decelerating.
Regards Pete
Post #2321 5th Jun 2008 11:09pm
mrwoo
Regards Pete
Yes that's right Pete, its at around 1900revs 4/5/6th gears at a constant speed without accelerating so around 40/50/60 mph depending on gear.
It's just been into Land Rover to have some swivel seals replaced and they said they couldnt find anything wrong with the engine.
Post #2325 6th Jun 2008 7:49am
bell-auto-services
I may be wrong but from the experience i have had on this engine and the transit van its self tome it sounds like the EGR actuation problem which at the moment is been addresed by Ford and i hope soon landrover.
Regards pete
Post #2326 6th Jun 2008 8:38am
mrwoo
Regards pete
Pete, I had one of the EGR blanking plates fitted to my 300 Defender before this and it definitely improved things. Does fitting an EGR blanking plate = a healthier engine with no detrimental effects?
PS where can I find the EGR on this engine?
Post #2331 6th Jun 2008 12:40pm
mse
Im just going through a dealer "theres nothing wrong" syndrome Big Cry Mike
Post #2335 6th Jun 2008 4:14pm
