Home > Maintenance & Modifications > Split charge system
bear100
Split charge system
Will soon need to fit a split charge system any recommendations on which system/make?
Any pointers on battery location, cable runs, etc etc
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #230010 23rd Apr 2013 9:19pm
GUM97
I've just got a Durite split charge relay in mine. It's the cheapest way I've found, and works perfectly well!
http://www.ebay.co.uk/itm/DURITE-SPLIT-CHA...0120726102
Mine cost me a damn site less than that, so if you want one give me a shout as I've got one here that I haven't used. Thumbs Up An engine to TDi for!
Post #230012 23rd Apr 2013 9:23pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I bought mine from X-eng, good quality, simple fitting instructions Thumbs Up
http://www.x-eng.co.uk/StoreDisplay.asp?SL=9&MID=4 Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #230015 23rd Apr 2013 9:27pm
Laurie
Diode blockers are the best but they do restrict the battery to about 80% max charge.
Post #230017 23rd Apr 2013 9:29pm
bear100
Chers guys Very Happy
Is it the done thing to fit a battery monitor? Any preference on battery makes.
Post #230033 23rd Apr 2013 10:05pm
leeds
There are many different ways of charging two batteries.
Basically you have to decide what features YOU want from a two battery set up.
Remember that the prime use of a car battery system is to start the car engine. If you can not start the car engine it might be awkward, might leave you up the creek without a paddle or even threaten your life!
Three types of batteries:
1) Starter battery
2) Leisure battery
3) Combined starter/leisure battery.
We would normally suggest two combined starter/leisure batteries.
A few questions for you.
Do you want a completely separate starter battery and leisure battery set up?
Do you want to cut into vehicle existing wiring?
Do you want the ability to join both batteries for winching purposes?
Do you want the ability to start the vehicle off the second battery?
Do you want a dual voltmeter?
For myself, I want the ability to start the vehicle off the second battery which means starter/leisure battery. Also I want the ability to combine batteries for winching.
That means a big relay
I would suggest looking at some of the Blue Sea relays or the IBS system. None of these involve cutting into existing wiring. Downside of them is they are more expensive then other means of just charging two batteries.
Brendan
Post #230046 23rd Apr 2013 10:35pm
JSG
The Tombraider 90 had a National Luna split charge system on it when I bought it complete with a monitor / control unit. Worked very well and an alarm if there was a problem.
I took it off when I sold it and will fit it to the 110 at some point. John
2011 Tdci 110 CSW XS
Post #230049 23rd Apr 2013 10:46pm
BigRuss
just bought one of these yesterday
http://www.mobilecentre.co.uk/index.php?ma...cts_id=582
Which should be delivered today Very Happy and I did by it from Tim.
I will be fitting it in about 5 weeks time Thumbs Up Russell
2011MY 110 XS USW Black
Post #230073 24th Apr 2013 3:20am
i have the same as Russ, fitted for about a year now, no issues, just works. i did not see the need for fancy gauges or rows of leds telling me there was electricity in my batteries. there's a simple carling rocker that tells me all i need to know. paired mine up with odyssey pc1500s and a devon44 tray
Post #230080 24th Apr 2013 7:09am
