Home > Puma (Tdci) > How high do you rev your 2.4tdci??
First90
2010 Defender 90 Puma 2.4 HT Alpine White
Just wondering how hard everyone pushes the Puma?
I mostly do short trips around town and shift in the high 2's because i am in traffi or its warming up. Then when going hard on or off road I go mid 3's but with my KM2's on I barely need that high.. At 4k it is screaming.
I have done 18,000kms and wonder whether I haven't really given it enough during its run in.
Post #227654 15th Apr 2013 9:40pm
Glynparry25
Regular driving I change between 2,800 and 3,000rpm. If having fun I will take it up to about 4,000rpm.
If you check out the BAS rolling road maps you will see that power starts to drop off at about 3,700rpm and then hits the cliff at just over 4,000rpm.
Powerband is about 2,400rpm through 3,700rpm anything over than and you are losing performance and it is pretty pointless (especially in Std map).
*EDIT* Forgot to mention, Torque starts to drop off just under 3,000rpm, so yes, you get more power but less torque so you are fighting a losing battle after about 3,200rpm.*
Glyn Dog Sheep
Post #227661 15th Apr 2013 9:47pm
spudfan
Ireland
2,000 rpm to 2,200 rpm 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #227672 15th Apr 2013 10:00pm
As above but occasionally hit higher if I need to momentarily I.e. having to pull out onto a fast road. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #227680 15th Apr 2013 10:22pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I'm with Glynparry25. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #227699 16th Apr 2013 5:34am
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Me too, although I run standard tune. Anything over 3,200 and you're starting to waste your time.
Post #227701 16th Apr 2013 5:44am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
+1 for Glynn. They aren't economical at the best of times, just drive it...... Makes a good bellow at about 4,000 after 4,500 starts to loose puff and sound a bit wheezy. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #227713 16th Apr 2013 6:57am
Naks
Until the engine is warmed up properly, I do not rev past 2200.
After that, I give it horns, sometimes upshifting at 3500-4000rpm while gunning it uphill. Thumbs Up --
Post #227716 16th Apr 2013 7:08am
Baggie Austin
England 2009 Defender 90 Puma 2.4 HT Alpine White
I dont tend to go over 2500rpm
Post #227718 16th Apr 2013 7:12am
First90
Seems we are generally in the same boat. I will stick to my low 2's and give it a few herbs from time to time to blow out any soot...
Also that is a sweet looking rig Baggie..
Post #227724 16th Apr 2013 7:33am
schuee
Generally between 2,200 - 2,500 and may hit 3,000 on the odd occasion Laughing
Post #227742 16th Apr 2013 8:55am
Porny
Site Sponsor
Depends on what mood I'm in... and what is trying to keep up with a farmers spec Defender lol.
This is one of the last runs on the rolling - as you can see it pulls from below 1200rpm and then gives a good bell shape of power (bhp). My 90 in current form will rev to just over 4500rpm - with over 100bhp at wheels from 1870rpm to about 3500rpm (peak calculates to 176bhp at 3100rpm).
In reality peak torque has come and gone - and we are talking diesels not petrol!
However, the 2.4 is a very rev happy diesel (the 2.2 even more so as is virtually a 'square' engine').... my 2.4 is back on the rolling road soon with more to come.
If we look at a Standard Defender 2.4 vs my entry level calibrations...
We can see a similar shape - but a much flatter bell shaped. With the standard calibration at 3500rpm you start hitting the roll out into the rev limiter (where the fuelling is removed to prevent engine over speed), so not much point reving much harder - and you are only getting 90bhp at the wheels max (118bhp at the wheels).... and you only get 85 ish bhp from 2800rpm to 3500rpm.
Ian
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #227743 16th Apr 2013 8:57am
MartinK
Normally I cruise around 1800-2200 revs in 6th.
I try & change up a gear as soon as I can, but without labouring it...Generally in the higher gears I keep it above 1700rpm unless downhill... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #227748 16th Apr 2013 9:26am
Baggie Austin
Thanks very much mate, just waiting for my clear indicators to arrive now Very Happy
Post #227841 16th Apr 2013 3:28pm
BigWheels
Max has been about 3200, smoother with better fuel. What mod is best at giving more torque at lower engine speeds? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #227969 16th Apr 2013 9:24pm
