- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Defender 90 TD5 1998 Overdrive fitting |
barbel jim
Roamer drive is just over £1000 then there's fitting. Most upgrade there transfer boxes to discovery gearing. Gives a 15% gain in final drive. 2 options buy a disco t/box and fit with a couple of small mods, or take your box and add the gearing. Ashcroft transmissions in Luton will fit it for you with 12 months warranty for £750 IIRC. It is something I seriously looked at, but then I do tow a bit and pootle around so stayed with the original gearing.
15th Apr 2013 4:53pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
