Home > Td5 > Squeak and rattling coming from 90
chinnus
2001 Defender 90 Td5 ST Coniston Green
Hi all, My Td5 90 has a couple of niggles as follows
ONE
A sqeak/squeal coming from the rear right wheel? What could it possibly be??
I dont think its something stuck on the disc as it has been going on for ages now?
TWO
And somewhere on the front of the car there is a clattering/rattling noise that only appears when coasting upto traffic lights for example. Under load or accelerating there is no noise?
any advice would be much appreciated
Post #220911 21st Mar 2013 3:32pm
JWL
When you find out, can you tell me what mine is Very Happy Eliminate brake pad rattle by feathering the brakes, if the rattle goes, then there is your cause. Mine sounds like a loose fixing somewhere underneath but I just can't trace it, I need some of those rare things..............time and some dry weather Rolling Eyes
Post #220916 21st Mar 2013 3:55pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Some years ago I had the same sort of noise from a rear wheel, changed pads and checked the disc, still no better.
early one morning I was driving along minding my own business when the 90 started to lurch to the off side then there was a sudden screech of rubber on tarmac and I came to a halt without touching the brakes, both rear wheels had locked due to seized wheel bearings.
Post #220919 21st Mar 2013 4:59pm
chinnus
cheers for the replies guys. I have jacked up the rear wheel in question and there is no play at all. I have rotated the wheel and there is a slight grate -ing coming from that wheel somewhere but also there is a grate -ing coming froom the big flywheel type part where there rear prop attaches to the centre diff. Is that the handbrake??
Still very puzzling[/code]
Post #221070 22nd Mar 2013 9:04am
landy andy
Is the squeak altered by road speed or bumps?
Is the front clattering noise also felt through the vehicle and very metallic, if so could be the diff. Mine made this sort of noise when at no load, accelerating and engine braking was quiet.
Andy
Post #221077 22nd Mar 2013 9:48am
chinnus
The squeak/grating increases in frequency the quicker you go... it appears to be coming from the bell/flywheel where the rear prop attaches to the transfer box? Is that the handbrake mechanism?
hmm the clattering noise doesnt appear through the vehcile it can only be heard when the window is down.. and sounds like the diff guard banging on the diff noise but obviously not that..
Post #221434 23rd Mar 2013 5:33pm
mk1collector
The clattering will be your brake pads rattling in the caliper. Try copper slip on the back of the pads and anti rattle shims.
Post #221492 23rd Mar 2013 8:37pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
re No1 check the bolts holding the rear corner of the the body to the tub. mine was loose and it gave similar symptons, gone once tightened BM52
Post #221501 23rd Mar 2013 9:04pm
chinnus
thanks for all the useful input will have a look at this over the next few weeks and post my results...
regards tom
Post #221539 23rd Mar 2013 11:32pm
chinnus
where do you buy anti rattle shims?
Post #221577 24th Mar 2013 10:27am
mk1collector
Landrover
Post #221580 24th Mar 2013 10:59am
Green Machine
Tom - yes that is the handbrake drum on the back of the transfer box Thumbs Up Don't know about the rattling I'm afraid! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #221584 24th Mar 2013 11:19am
barbel jim
Thread revival Whistle
I have an annoying rattle similar to your description, has to be driveline related. Only noticeable on over run, dip the clutch it stops. Not noticeable on acceleration. I have checked UJ's , not brake pad rattle ........ Stumped. . Did the op ever resolve this ?
Post #368726 1st Nov 2014 1:12pm
bob neville
Hi Jim
Just come in from trying to find a nasty rattle/knock on my TD5.
First thought was it was related to the x-brake I fitted a few weeks ago so I removed it and went for a short drive and the knock/rattle is still there. Replaced the brake and went for a drive with the centre plate off. Knock is there under load and if a rev the engine when stationary I can here a rattle from the bell housing area.
My immediate thoughts are the DMF/clutch. It seems OK in low range and I have no judder on take up so am a bit mystified.
Just booked it in for the end of next week to try and get it sorted - I know it is going to be expensive Big Cry
2013 Defender 90 CSW - sold
Post #368776 1st Nov 2014 4:44pm
barbel jim
Hello again Bob
Mine as far as I can tell only on over run. I've tried listening stationary , and get nothing only the usual clatter ! I was hoping it would be the uj's but noooooo ! My worry is the longer I leave it the more it will cost ! Push the clutch in it disappears, hence my similarity with OP. Fast approaching 98k still on original clutch so DMF could be a possability. Big Cry
Post #368786 1st Nov 2014 5:14pm
