![]() | Home > Puma (Tdci) > Puma Electric Library AKA connectors car layout and pinout |
pm me Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Dgardel me old mucker,
PM sent, you should have something sitting in your e-mail inbox. Hopefully this is what you were after? ![]() Happy days! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
K9F
Do you have the 2007 MY wiring diagram ? If you have, would you be so kind as to PM me the section/page with the heated seat wiring. Having changed to Exmoor Trim seats I need to rewire and in the process use multi position switches to allow me to use the hi/lo settings for the new heater elements. It will be easier if I can pick up the existing LR heated seat circuit where possible. Thanks in advance - Bob |
Thanks Daz
I have not done anything yet as my seats are being replaced by Exmoor due to a problem with the leather. The new seats have just arrived at Exmoor so I was getting ready to wire everything up ! Bob |
