Home > Puma (Tdci) > Puma Electric Library AKA connectors car layout and pinout
dgardel
Italy
pm me Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #22058 13th Jan 2010 10:49pm
K9F
PM Sent
Dgardel me old mucker,
PM sent, you should have something sitting in your e-mail inbox. Hopefully this is what you were after?
Thumbs Up
Happy days! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #22072 14th Jan 2010 9:24am
bob neville
K9F
Do you have the 2007 MY wiring diagram ?
If you have, would you be so kind as to PM me the section/page with the heated seat wiring. Having changed to Exmoor Trim seats I need to rewire and in the process use multi position switches to allow me to use the hi/lo settings for the new heater elements. It will be easier if I can pick up the existing LR heated seat circuit where possible.
Thanks in advance - Bob
Post #22078 14th Jan 2010 10:49am
DAZ110
Hi Bob,
When I connected my Le mans seats up I put the black of the original land rover wire to the black of the seat wiring and the yellow of the original land rover wiring to the green of the seat wiring.
The red wire left on the seat wiring I cut off and didn't use.
The seats get hot enough this way and you continue to use the original land rover switches.
Thanks
Daz110
Post #22090 14th Jan 2010 1:16pm
bob neville
Thanks Daz
I have not done anything yet as my seats are being replaced by Exmoor due to a problem with the leather.
The new seats have just arrived at Exmoor so I was getting ready to wire everything up !
Bob
Post #22091 14th Jan 2010 1:34pm
