Home > Puma (Tdci) > Foam inner door card
Delskinz
England 2007 Defender 110 Puma 2.4 SW Tonga Green
Does anyone know the part number or where I can find a new foam weather inner door card? I've tried the usual suppliers web sites but as I don't know the parts real name I'm struggling.
BTW the reason I ask is my Puma has had a leak from the rear o/s door area. After taking the outer card off the foam is ripped at the bottom so letting rain in from the window sill.
Post #219924 17th Mar 2013 4:40pm
Killer90
Site Sponsor
called a water shedder mate Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #219933 17th Mar 2013 5:06pm
Killer90
Site Sponsor
Front RH door is - EJD500620 £8.22
Front LH door is - EJD500630 £8.22
110 Mid row RH is ELD500400 £7.48
110 Mid row LH is ELD500410 £7.48
Thumbs Up Thumbs Up CSK Automotive
Post #219935 17th Mar 2013 5:08pm
Delskinz
Cheers buddy!
I will have dry truck...I will
Post #219956 17th Mar 2013 5:39pm
Killer90
Site Sponsor
Delskinz wrote:
Cheers buddy!
Rolling with laughter Rolling with laughter clever how they work really as all the water goes down them and out the bottom Thumbs Up check your bottom door sills as they can sometimes keep the water in there Thumbs Up CSK Automotive
Post #219959 17th Mar 2013 5:42pm
Delskinz
Looking at FCX's new 130 he's put Dynamat under the door card. Would it work as a water shedder too?
Post #220041 17th Mar 2013 9:50pm
Killer90
Site Sponsor
Thumbs Up Yer would work the same, the Dynaliner looks very similar aswell to the Genuine foam. Thumbs Up CSK Automotive
Post #220053 17th Mar 2013 10:23pm
Delskinz
I see a plan forming.......mwhahahaha Twisted Evil
Thanks again for the advice!
Post #220061 17th Mar 2013 10:32pm
Killer90
Site Sponsor
Wink excuse to get some dynamat i suppose Whistle Laughing CSK Automotive
Post #220064 17th Mar 2013 10:35pm
Delskinz
Just replaced the water shedder which was letting in water behind the door card and on to the rear carpets.
This was "the before"picture - the bodged tape work looks like it was original out of the factory Shocked , taking the door card off there was no sign of previous access to behind the card (plastic studs were perfect, the lock shroud was a pig to get off, screw heads looked good etc etc).
Post #220637 20th Mar 2013 1:42pm
Delskinz
Following a night of heavy rain...............NO LEAKS!!!
If anyone is struggling to find a mystery water leak take a look at this, for an £8 repair its worth checking.
Post #220837 21st Mar 2013 8:30am
