![]() | Home > Puma (Tdci) > Service bulletin Q068v2 |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
I just had my software upgrade and its really improves the power and less roughness on the engine. thanks guys!
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
Had mine done this morning, a lot smoother and quieter
you've been coasting down the hill again have'nt ya 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
My consumption has now dropped to 11,3l/100
jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172 ![]() ![]() ![]() |
I do 10 without the AC. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
Ollram Member Since: 04 Jun 2007 Location: Athens, Greece Posts: 13 ![]() ![]() ![]() |
i will probably join your "club" owing a defender 110 SVX. However, teh serial no showed that the specific vehicle i'll buy, hass an open field service action, the Q068....
i guess that the previous owner has does all required with LR...but as a novice myself, how serious could be this fault??? cheers guys |
Hi Ollram it's not a fault it's just a new patch....no need to worry.. you're dealer should now if its been done or not give them a bell and they will let you know mate NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
QO68v5 is now out 2.4 90 XS
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Can you post a copy? |
If you have a copy of previous version THE TEXT CONTENT IS THE SAME!!!!
change the pacth files that dealer use..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Would these updates not affect the number of re-writes on the chip which has only 15 re-programmes before the whole ECU has to be replaced?
Just a thought. ![]() |
Right you wrote Cape.... the 15 times limit is ONLY A SAFETY/MARKETING (eg BMW limit is "only" 12...) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Post for BAS Pete.....
Pete, the reprogramming limit is valid for BAS remap too???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Hi, No this does not apply to the BAS remap interface you can program it as many times as you wish with my interface. ![]() We think like landrover some times, but others times think better ![]() Pete |
