Home > Puma (Tdci) > Service bulletin Q068v2
Page 6 of 8 <12345678>
totoD110
I just had my software upgrade and its really improves the power and less roughness on the engine. thanks guys!
Post #19318 2nd Dec 2009 12:39pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Had mine done this morning, a lot smoother and quieter Razz Cogito ergo sum
Post #20195 15th Dec 2009 4:52pm
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
It is a fantastic upgrade. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #20204 15th Dec 2009 6:01pm
Grockle
you've been coasting down the hill again have'nt ya 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #20250 16th Dec 2009 10:59am
CapeLandy
South Africa
My consumption has now dropped to 11,3l/100 Very Happy
Post #20286 16th Dec 2009 7:17pm
jamesbond007
I do 10 without the AC. Boldly going nowhere
Post #20292 16th Dec 2009 8:31pm
Ollram
Greece 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
i will probably join your "club" owing a defender 110 SVX. However, teh serial no showed that the specific vehicle i'll buy, hass an open field service action, the Q068....
i guess that the previous owner has does all required with LR...but as a novice myself, how serious could be this fault???
cheers guys
Post #21945 12th Jan 2010 5:56pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Hi Ollram it's not a fault it's just a new patch....no need to worry.. you're dealer should now if its been done or not give them a bell and they will let you know mate NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #21947 12th Jan 2010 6:16pm
Grockle
QO68v5 is now out 2.4 90 XS
Post #21970 13th Jan 2010 8:24am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Grockle wrote:
QO68v5 is now out
Can you post a copy?
Post #21988 13th Jan 2010 12:55pm
dgardel
Italy
If you have a copy of previous version THE TEXT CONTENT IS THE SAME!!!!
change the pacth files that dealer use..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21991 13th Jan 2010 1:26pm
CapeLandy
South Africa
Would these updates not affect the number of re-writes on the chip which has only 15 re-programmes before the whole ECU has to be replaced?
Just a thought. Shocked
Post #21992 13th Jan 2010 1:26pm
dgardel
Italy
Right you wrote Cape....
the 15 times limit is ONLY A SAFETY/MARKETING
(eg BMW limit is "only" 12...) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21994 13th Jan 2010 1:33pm
dgardel
Italy
Post for BAS Pete.....
Pete, the reprogramming limit is valid for BAS remap too???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21995 13th Jan 2010 1:35pm
bell-auto-services
Hi, No this does not apply to the BAS remap interface you can program it as many times as you wish with my interface. Mr. Green
We think like landrover some times, but others times think better Smile
Pete
Post #22000 13th Jan 2010 2:36pm
