Home > Puma (Tdci) > Funny idle
Tubes63
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Funny idle
Ok, so my idles been acting weird for some time now. Its rough in the cold, then fine when it atarts warming up and then rough and hunting again after its properly warm and after a good run. I took it to Chris and there are no error codes on it at all. The oils just been changed and it's not using oil, it's not milky, and the coolant is red and not getting used either.
There was a little puddle of liquid around the fuel rails and down the oil filler cap which I took a photo of so hopefully I'll put that up in a sec. I also have a video of the engine crapping around at idle.
There is also smoke coming out of the filler cap when I take it off.
Any ideas on where to start looking? Geoff
2007 Defender 90
Post #215559 2nd Mar 2013 5:52pm
Tubes63
I should add that it seems to drive fine. And fuel economy seems to be ok. I'm currently at 210 miles on half a tank. Geoff
2007 Defender 90
Post #215560 2nd Mar 2013 5:56pm
Killer90
Site Sponsor
Confused Confused is very strange it drove so well and acted normally when it was here to look at the problem you keep saying about Crying or Very sad always the way though mate. Upload the photos Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #215561 2nd Mar 2013 5:59pm
Tubes63
[img]http://i214.photobucket.com/albums/cc59/spaztasticmania/AA7E16B7-91F0-4F89-9F76-B941BBF88559-614-0000011CB5A0BEA1_zps456f3493.mp4[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Geoff
2007 Defender 90
Post #215565 2nd Mar 2013 6:14pm
Lorryman100
Is the puddle around the fuel rail, diesel? I noticed that the fuel return and injector pipes are dry on the pictures, did you wipe anything before taking the pics? Easy fix would be a burst return pipe causing the leak but this would not affect the engine idle. When you were at Chris's was the tool you used to check the DTC codes a generic reader or a diagnostic tool? Did you check the injector bolts nearest the puddle?
Post #215568 2nd Mar 2013 6:26pm
Tubes63
I didn't wipe anything, no. And I poked my finger into the puddle but I couldn't smell anything over the ordinary greasy stench that comes from lifting the bonnet.
I don't know what Chris used to read the codes, though I assume he does Laughing
obviously the videos haven't uploaded correctly Confused Geoff
2007 Defender 90
Post #215569 2nd Mar 2013 6:31pm
Tubes63
I was thinking it would be something to do with the oil since it was smoking when I took the cap off... Isn't that a sign of over pressurization or something like that? Geoff
2007 Defender 90
Post #215570 2nd Mar 2013 6:33pm
Lorryman100
The only real way to find out for sure would be to use a diagnostic tools live data page to watch the engine idle and rail pressure readings to discount the high pressure fuel rail/injectors as the cause of the puddle. The smoke from the filler cap could be due to over pressurizing of the crankcase, is the breather clean? I am a bit at a loss as to you having no DTC's logged at all, this is strange as untested/pending DTC's are nearly always present in all the Puma EMS systems I have seen? If it was a badly seated injector, leaking injector etc a DTC would be logged for an, "Injector ? imbalance". If it was an issue with the fuel flow from the tank, blocked filter, contaminated fuel lines etc then I would be looking for the operation of the VCV using a picoscope to see how far open the valve was at a set rpm eg, Idle, 2000rpm etc. I would be checking the puddle to see if it was diesel or not, if not then move onto the fuel filter and feed pipes as these would give the uneven running symptoms without logging a DTC.
I may not be able to reply further to your posts tonight as I am away from home using a sh**ty dongle in a gsmr area that has very limited signal reception.
HTH Brian.
Post #215575 2nd Mar 2013 6:51pm
dgardel
Italy
Check the injectors fixing screw, seems that the injectors are splitting somethings ...
....I care about "black" deposits at the base of the injector..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #215580 2nd Mar 2013 7:15pm
Tubes63
I'll try and find the crankcase breather, though it obviously doesn't look like the one on my old v8 because I can't see it anywhere right now Whistle
I'll try and get some more info tomorrow, though I'm supposed to be working & entertaining tomorrow Big Cry Geoff
2007 Defender 90
Post #215581 2nd Mar 2013 7:18pm
Tubes63
Yeah it is worrying, dgardel... But since there isn't a Haynes manual for the tdci I'm having trouble finding these things Whistle Geoff
2007 Defender 90
Post #215582 2nd Mar 2013 7:23pm
Tubes63
So this problem just got worse quite rapidly... Tonight went to Leominster, and driving down my parents drive i have to open and close two gates. It stalled every time I stopped (after a few seconds of hunting). This was when the engine was cold. It was also lumpy on acceleration for a while and sounded a bit... odd... Then once it was warm it was fine (still idling rough, but no stalling).
Driving back to Stevenage through central london tomorrow so fingers crossed Sad will need to get it seen to asap by someone as I need her to be in a-1 condition when I move at the end of march.
Not good. Geoff
2007 Defender 90
Post #215668 2nd Mar 2013 11:12pm
Killer90
Site Sponsor
Geoff, have you checked that Engine Oil level mate, As i said to you it was pretty low even when you said you topped it up the other day. Just check it isn't eating the oil up baring in mind i put fresh oil in and filled it to the level Thumbs Up CSK Automotive
Post #215671 2nd Mar 2013 11:30pm
Tubes63
I checked it earlier today and it looked 100% full... Though it took me a while to figure it out because I'm used to oil looking black and it still looks brownish clear. Thumbs Up So not eating oil I don't think. Will check before I leave tomorrow. Although I have spotted a couple blue clouds for a few seconds when she's first started. Geoff
2007 Defender 90
Post #215672 2nd Mar 2013 11:32pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
not sure if thes help, just taken from the manual:
The ECM detects injector faults based on the power consumption of the solenoid valves. In the event of a fuel injector
failure, any of the following symptoms may be observed:
Engine misfire
Idle faults
Reduced engine performance
Reduced fuel economy
Difficult cold start
Difficult hot start
Increased smoke emissions
Engine stops/stalls
Air leakage
Low/contaminated
fuel
Low-pressure fuel
system fault
High-pressure fuel
leak
Fuel suction control
valve
blocked/contaminated
Exhaust gas
recirculation (EGR)
valve fault
Check the intake air system for leaks. Check the fuel level/condition. Draw off
approximately 1 ltr (2.11 pints) of fuel and allow to stand for 1 minute.
Check to make sure there is no separation of the fuel indicating water or
other liquid in the fuel. Check the fuel system for leaks/damage. Check for
DTCs indicating a fuel suction control valve fault. For EGR valve checks:
REFER to: Engine Emission Control (303-08 Engine Emission Control - 2.4L
Duratorq-
Rough idle Intake air system
fault
Low/contaminated
fuel
Low-pressure fuel
system fault
Blocked fuel filter
valve
Exhaust gas
recirculation (EGR)
valve(s) fault
other liquid in the fuel. Check the low-pressure fuel system for leaks/damage.
Check the fuel filter, check for DTCs indicating a fuel suction control valve
REFER to: Engine Emission Control (303-08 Engine Emission Control - 2. BM52
Post #215676 3rd Mar 2013 12:24am
