Home > Td5 > Td5 original horn set up |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
Mine has one horn on the nearside. Not found the wiring for the second, but haven't looked very hard.
21st Feb 2013 7:31pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
2001 90, horn on nearside and wiring on the offside.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Feb 2013 7:36pm |
Cool. I might look for the plug on mine then.
21st Feb 2013 7:40pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
I replaced mine with a nautilus. Which only works with the alarm. So I think, horn one side, alarm horn the other?
21st Feb 2013 7:47pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 558 |
My 2005 xs has them on both sides and both sound when horn is pressed, maybe it's an option
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
21st Feb 2013 8:23pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Think it was an option to have a "high tone" and a "low tone" together, should be plug & play
21st Feb 2013 8:34pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Thanks chaps. I fitted a second horn a while back and indeed it was simply plug and play. Both now sound when the horn is pressed and indeed when triggered by the factory alarm. In fact the second horn works perfectly independently in both scenarios too.
So it sounds like unless the high/low option was specified the Td5's would have left the factory with just a single horn. Sure you can see where I'm going with this. Jon - 110 td5 [sold]. Currently Defenderless. |
21st Feb 2013 9:23pm |
3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44 |
Mine's a Nov 2006 build, It had one horn in N/S wing and wiring in other side but no Horn. I fitted a Stebel Nautilus Truck Air Horn on this side. If I give the horn a quick jab you get the one horn, but if you press the Horn for more than a nano second you get the truck horn as well. This is reserved for who pull out in front of me or cut me up Col. 1979 Series 3 109 FFR (ex Aust Army.) 2006 Defender TD5 110. 2012 Trackabout CT. |
22nd Feb 2013 12:02pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Must be. Mine only came with one. |
22nd Feb 2013 12:09pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
My 110 is using 50th loom which has two connections. I have fitted one horn and bracketry from Td5, but am struggling to find the bracket for the other side. Its an angle bracket which is hannded. Dealer has struggled to find part number for me. I have given up for now.....but if anyone knows more ?
22nd Feb 2013 6:09pm |
Best guess chap is that you want the following..... RH - ASU710060 LH - ASU710070 I got the part number info on the interweb somewhere, so I ordered both from Duckworths a couple of months ago (2.20+VAT each at the time), given that for a couple of quid each, it was easier to order both than end up with the wrong one from a bum steer Piccy of both if that helps confirm they look like what you need ?? I just need to get around to making a proper job of fixing the new horn as currently, I'm using a horn+bracket from a scrapped Rover 75. Works perfectly but the rover bracket orientation is wrong and that just annoys me Jon - 110 td5 [sold]. Currently Defenderless. |
22nd Feb 2013 11:47pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
Mine is farmer spec and it came with two. So it's the luck of the draw, I guess. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
4th Mar 2013 11:08am |
Thank you Party Monkey
4th Mar 2013 5:59pm |
