Home > Maintenance & Modifications > Steering wheels topic.......again!!
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Quick question......will the Defender steering wheel with the 'lump' in the centre fit the previous models' column, the one with two thick spokes? I think both have 48 splines but may be wrong!!! Being lazy, trying to avoid chassis number lookup.
Ta.
Post #212624 20th Feb 2013 11:56am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
About the only definitive way to workout the number of splines is to take off the steering wheel and count them!!
Land Rover did have a habit of using what ever they had to hand.
Post #212626 20th Feb 2013 12:11pm
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
its either 36 or 48, but as dnorrishill says theres only one way to find out! 90 XS
Volvo V70
Post #212641 20th Feb 2013 2:00pm
geobloke
And you do not have to take the wheel off before counting the splines, merely undo the nut and washer and count with the current wheel in place.
Post #212642 20th Feb 2013 2:26pm
chipmunk
Did have an ex RAF 90 with the four spoke horrible wheel on it, I thought they had changed the column when it became the Defender and it remained the same? Spline wise I mean. Don't want to take wheel off if possible, there is an XS Leather on FB I'm interested in.
Cheers.
Post #212644 20th Feb 2013 2:31pm
chipmunk
Ta Geo, must have posted last entries at the same time.
Post #212645 20th Feb 2013 2:33pm
geobloke
IIRC the older 4 spoke steering wheels are 36 spline, same as some TD5 defender and Classic RR steering wheels. Certainly my 2002 110 CSW had a 36 spline but for some reason some TD5s were sold with the 48 spline steering wheels found on the TDI Defenders.
Post #212646 20th Feb 2013 2:48pm
XS wheels have been produced in both 36 spline and 48 spline.
Poverty spec 90 / 110's etc used to have 48 spline steering columns and County spec vehicles were 36 spline - this continued until 'about' 2008 when ALL steering columns became 48 spline.
Therefore a pre 2008 XS wheel will be 36 spline and will only fit County spec vehicles up to about 2005 (between 2005 and 2008 you get a complete mix and match)
Hope that helps - By the way I have a brand new take off 48 spline XS wheel for sale ....
Post #212647 20th Feb 2013 2:50pm
chipmunk
So the 48 is the older one? Always thought it was the 36 that was the older.
Post #212648 20th Feb 2013 2:52pm
No, read my post again.
The 36 spline XS wheel (Only the XS wheel not the standard wheel) is the older one Thumbs Up
Post #212650 20th Feb 2013 2:55pm
So if your 2003 is a poverty spec it will have a 48 spline column (from the factory)
Post #212651 20th Feb 2013 2:59pm
chipmunk
And again, posts were entered at the same time. Is the XS wheel for sale Leather and price please? Will take nut off and count splines........after I've cooked the tea and fitted some garden gate furniture...........exciting stuff. Wish it was Spring.
Post #212654 20th Feb 2013 3:01pm
chipmunk
Mine is 03 90 County Hardtop.
Post #212655 20th Feb 2013 3:02pm
Here you go mate, yes Leather (All XS wheels were)
http://defender2.net/forum/topic18449.html
Post #212656 20th Feb 2013 3:03pm
Then you need to check but I will bet it's a 36 spline if a 'true' County spec ....
Post #212657 20th Feb 2013 3:04pm
