Home > Technical > how high ? help |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 |
ok stooooopid question , but i have a 07 57 model, does anyone know how high this baby is.
its fitted with standard grabber tyres, the reason i ask isb i dont want to take the roof off going into a car park help pls |
12th May 2008 2:57pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
from memory 2.05m - Look in the handbook its all in there Mike
12th May 2008 4:38pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
The overall height (2021mm for the 110 in the spec. sheet) is not as much of a problem as the "kick-up" at the rear when going down ramps. I don't chance anything under 2.2m because of this.
For example, ramping down a 1 in 5 gradient (11.3deg), which is the steepest permissible ramping angle in a public car park (according to Australian Standards), the back kicks-up to about 2212mm above the flat floor at the top of the ramp! The main problem is that car park height gauges DO NOT take this into account - they only indicate the clear head height on a flat surface. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
12th May 2008 11:24pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
I'm sure mine said 2.06 m.
It fits fine in two local car parks with 2.1m limit signs. |
13th May 2008 9:10am |
If this is any help
Floor to gutter is 1.91 gutter to bottom of the roof tent is 20cm so the total with a roof bar *should* be 2.11m Mike |
13th May 2008 4:53pm |
Hmmmm clear as mud, thanks anyway peops
15th May 2008 7:14am |
Just look in the manual - if i remember next time i go in it ill look Mike
15th May 2008 7:38am |
THANKS FELLA
15th May 2008 7:41am |
Yes - and as I posted earlier in the htread the manual will say 2.06m |
15th May 2008 7:42am |
Thats my point, isnt that then the answer Mike |
15th May 2008 7:45am |
Nope - it's only the answer on a flat surface. How many car parks have ramps in them? I stand by my calculation of 2212mm on a 1 in 5 gradient. 2.2m in public car parks gives a suitable safety margin. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
15th May 2008 8:47am |
Different question. The original question was 'Hoe high is an 07 Defender?' The answer is 2.06m for the 110 |
15th May 2008 9:55am |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 |
264 meters above sea level if that helps
15th May 2008 12:17pm |
Nope (again) - Same question, different possible circumstances. In relation to the original question which was in the context of car parks, I stand by my expanded answer. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
16th May 2008 5:40am |
