Home > Technical > how high ? help
NCTT
how high ? help
ok stooooopid question , but i have a 07 57 model, does anyone know how high this baby is.
its fitted with standard grabber tyres, the reason i ask isb i dont want to take the roof off going into a car park help pls
Post #2078 12th May 2008 2:57pm
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
i thought that the fully extended radio aerial was the same height as the roof on a defender, eg if you go to drive into the car park and the aerial hits, so will your roof. if not you'l be ok. (don't take my word for it though as i may be wrong.....) Rolling Eyes
Post #2079 12th May 2008 4:18pm
mse
from memory 2.05m - Look in the handbook its all in there Mike
Post #2081 12th May 2008 4:38pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
The overall height (2021mm for the 110 in the spec. sheet) is not as much of a problem as the "kick-up" at the rear when going down ramps. I don't chance anything under 2.2m because of this.
For example, ramping down a 1 in 5 gradient (11.3deg), which is the steepest permissible ramping angle in a public car park (according to Australian Standards), the back kicks-up to about 2212mm above the flat floor at the top of the ramp! The main problem is that car park height gauges DO NOT take this into account - they only indicate the clear head height on a flat surface. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2086 12th May 2008 11:24pm
JSG
I'm sure mine said 2.06 m.
It fits fine in two local car parks with 2.1m limit signs.
Post #2091 13th May 2008 9:10am
mse
If this is any help
Floor to gutter is 1.91 gutter to bottom of the roof tent is 20cm so the total with a roof bar *should* be 2.11m Mike
Post #2102 13th May 2008 4:53pm
NCTT
Hmmmm clear as mud, thanks anyway peops
Post #2117 15th May 2008 7:14am
mse
Just look in the manual - if i remember next time i go in it ill look Mike
Post #2118 15th May 2008 7:38am
NCTT
THANKS FELLA
Post #2119 15th May 2008 7:41am
JSG
Yes - and as I posted earlier in the htread the manual will say 2.06m Whistle
Post #2120 15th May 2008 7:42am
mse
Thats my point, isnt that then the answer Thumbs Up Mike
Post #2121 15th May 2008 7:45am
solmanic
Nope - it's only the answer on a flat surface. How many car parks have ramps in them? I stand by my calculation of 2212mm on a 1 in 5 gradient. 2.2m in public car parks gives a suitable safety margin. 2007 Defender 110
Post #2122 15th May 2008 8:47am
JSG
Different question.
The original question was 'Hoe high is an 07 Defender?' The answer is 2.06m for the 110 Very Happy
Post #2123 15th May 2008 9:55am
Alex e
264 meters above sea level if that helps Wink
Post #2124 15th May 2008 12:17pm
solmanic
JSG wrote:
Different question.
Nope (again) - Same question, different possible circumstances. In relation to the original question which was in the context of car parks, I stand by my expanded answer. 2007 Defender 110
Post #2127 16th May 2008 5:40am
