Home > Other Site Sponsors > F/S Job lot of Interior LED Lights |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Thats a great comparison Lee
Here are my ones fitted to a local customers 110 at night CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
5th Feb 2013 11:40pm |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 |
Sorted mine today (after some advice from Chris ) and very happy
Cheers Chris |
6th Feb 2013 10:49am |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Haven't fitted mine yet. How do I not blow my fuse?
6th Feb 2013 12:20pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Overide the switch to turn the light off before removing the old bulb.
If there is a perm live up there, the only thing that will blow the fuse is touching earth, so that can only be the other side of the connector which is what the door switch earths. The power switch will either pass the earth down to the door or to perm earth (switch set to on). Other than that, just be careful....? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
6th Feb 2013 12:23pm |
The issue is that the backplate of the light fitting, which is permanently live, is quite large, so it's very easy to create a short between it the earth terminal. Taking the fuse out before fitting is an easy solution but if using the springy adapter to the typical panel-type LEDS then I was worried that it might move or flex in use and still make contact later. Hence my suggestion of a square of insulation tape. That's probably less of a concern with a 'fixed' bulb. Darren
6th Feb 2013 12:43pm |
But if the light is switched off, there is no earth surely?
As far as I know, the interior light is earth switched. If the switch is set to "door", the door pins earth the light. If the switch is set to "on", the switch earths the light If the switch is set to "off", there is no earth present. I could be wrong, and usually are, but if the light is off, then there is no way of earthing it. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
6th Feb 2013 12:51pm |
Oh I'll just say a little prayer.
6th Feb 2013 1:30pm |
\ Just take it easy when fitting them CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
6th Feb 2013 1:37pm |
Or to be fully safe, disconnect the battery and wear a rubber suit.! Craig Rogers
6th Feb 2013 1:39pm |
i can imagine it now, what the neighbours must think CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
6th Feb 2013 2:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
Don't tell me your not tempted if it was white Chris. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
6th Feb 2013 3:53pm |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
Received mine today
6th Feb 2013 4:26pm |
good to hear mate CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
6th Feb 2013 6:28pm |
Maybe CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
6th Feb 2013 6:29pm |
