Home > In Car Electronics > 4 Channel Amp with variable HPF on both outputs. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Matt, can you report back on them, I am looking for some new speakers
Glyn |
6th Feb 2013 12:48pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
I will do mate, it'll be a few weeks yet as we are aiming to unveil the 130 leather dash at the Donington show and then install it the week after
6th Feb 2013 12:52pm |
Terrible customer service...... I WANT TO KNOW NOW!!!
Glyn |
6th Feb 2013 12:53pm |
Believe me, I WANT TO KNOW TOO !
6th Feb 2013 12:54pm |
True
Take a look at their amps as well, obviously I can't comment on performance (yet) but the build quality certainly looks good |
6th Feb 2013 1:00pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
http://icedotcomexpress.com/speakers-compo...-3424.html
These are what I am running currently in the front. Did a direct comparison with focal K2, and to my ear came a very close second. Use the fronts just to infil the sound, need the tweeter more than anything else as the fronts just point at your legs or floor. Run of an amp or just head unit. Amped 6x9 enclosures in the rear and a alpine active sub on the bulkhead. Get a really balenced set up with a quality sound, however am looking at swapping the sub. Its good, but runs out of guts and gets dawarfed by the 6x9 once your start to turn it up. |
6th Feb 2013 1:01pm |
I've got a 150w Alpine powered sub and I'm worried that it wont cut the mustard, any suggestions baring in mind I've got a crew cab so all room ?
6th Feb 2013 1:06pm |
A shallow sub in a homemade custom enclosure under somewhere like the rear seats ???? 8 or 10 inch, if room 2 8" ???? The alpine is good SWE1000 I think, works a treat at low volume to mid. Depending on the music though,
sometimes you need to feel the beat as well as hear it !!!! It just completes the experience Some of the shallow mount subs don't need massive boxes say 10" x10" x4" if that helps. Find smaller 8-10 " are more responsive and punchy, so I would sooner have 2 than 1 big one. The big subs have a habit of blurring notes. In this case you the get quantity as well as quality. Although 1 8" proper sub set up will beat what youv,e got Last edited by barbel jim on 6th Feb 2013 1:18pm. Edited 1 time in total |
6th Feb 2013 1:14pm |
I hate the advertising of that company and it rung alarm bells straight away. They state 400W peak power which is 100W more that 'theloudest.com' so I looked for the RMS value (as that is what is important) and they don't state it anywhere. The closest I can find is the recommended Amp power and they state it should not exceed 50W RMS and 125W Peak....... So it is running at a maximum of 50W RMS..... which is nearly half the 'theloudest.com' Still better than what I am running though Glyn |
6th Feb 2013 1:15pm |
Thank you I'll take a look at an 8" set up |
6th Feb 2013 1:20pm |
What have you got behind the rear seats?..... My plan is to make a board that starts on the floor up to just below the rear window (where the trim ends). It will be a triangle shape that spans the whole width of the cab. I will then mount my 12" in the middle and low and calculate the litres needed. the area needed will then be boxed in- no ports as that normally doubles the volume needed. Then at the ends I will then see what space I am left with and to box a set of other speakers (hopefully 6x9). There will be plenty of room then under the rear seat/ bolted to the board for the amplifier. To finish it all off it will be trimmed up in black carpet to match the rest of the cab.
Glyn |
6th Feb 2013 1:23pm |
I know what you mean Glyn. Its run by a couple of brothers , who make me smile every time I see them. Think its all part of the way companies like to appear bigger than they are. The shop is a real Aladdin's cave, but they are harmless and good fun, so I use them if I can. Only posted the link to show there are other options. I herd them and tested before I brought them. RMS can be very over stated similar to tyre size I find. Earthquake are american and were the kid on the block 15 years ago. I tried them out against the focals K2 and they were a very close second to my ear and it did not warrant another £150+ for focal. Anyways at 70 in a defender the quality is somewhat comprimised
6th Feb 2013 1:27pm |
Nothing at the moment, I've got a pair of theloudest.com 6 x 9's to fit and am open to ideas
Click image to enlarge The amps are already under the seats: Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
6th Feb 2013 1:28pm |
presume that is all MDF made ? looks smart. could you not box it off , seperate enclosures for the 6x9 ? I agree with Glyn enclosures all the way no ports. His suggestion behind the seats sounds good for the subs, although I wouldnt want to be sitting in the back when you turn it up :rolllaugh: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
6th Feb 2013 1:36pm |
