Home > Maintenance & Modifications > Original style LED lights |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20413 |
If only you'd change the rest to clear also. I'm sure you wouldn't regret it. $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
8th Jan 2013 4:10pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
SAME!! thats exactly what i have red brake lights clear indicators cheers Steve CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
8th Jan 2013 5:23pm |
We'll I think you all best get upgrading then. $W33T $0U7H3RN $UG4R
8th Jan 2013 5:31pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Thanks for the heads up on these lights from Bolt on Bits. I have had them on for 2 weeks as a stop gap to purchasing the river runner ones, but these do the same job for a lot less cash and they look oem though probably nowhere near the quality of the river runner ones, but they are staying on the Puma, and for £120 with the relay I'm more than happy. Not sure about the looks of the reversing light and fog from BoB though? I'm thinking I will get the fog light from Dun-Bri and just upgrade the reversing lamps bulb with a 16w Cree one off the bay? Any other options out there?
I went for clear on the front and coloured on the back end, just like the originals on my XS. |
1st Feb 2013 4:58pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 660 |
Did the adjustable BoB relay work for you? Didn't for me. I either got fast flash or the LED's would stay on continuously with no in between no matter what the setting.
Cheers Steve |
1st Feb 2013 6:04pm |
Yes works fine. Only one issue and its a small one, is that the flash is a little slower over the OEM flash rate. I thought that the adjuster on the top of the relay is only there to get rid of the trailer icon on the IPAC when there is no trailer attached? I think I will order one of mobilecentres relays and see if that improves the flash rate, then again I could just be havering on about nothing.
1st Feb 2013 6:19pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
Whoops, just bought a set of those... it's a slippery slope to £800 LED headlights
1st Feb 2013 6:35pm |
Hooo yesssss but JW Speaker LED Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Feb 2013 12:20pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I have had the BoB LED's including the fog and reverse fitted now for about 6 months and they are great. They plugged straight in and the relay worked fine too. Really happy with them.
2nd Feb 2013 4:37pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
I don't quite understand the equipping of a vehicle that does rough dirty work with very expensive lighting that might get wrecked.
Unless of course you're all posey boulevard cruisers. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
2nd Feb 2013 6:35pm |
