Home > Maintenance & Modifications > Alternative LED headlights
Page 3 of 4 <1234>
nakatanenga
Germany
The Nolden / Startech ones are available in RHD and LHD in April.
If got a set of engeneering samples in my 130 fitted from last week on.
They are GREAT!!! And i have tested them all! WANTED:
SII or SIII in max 1.5k
Post #206473 29th Jan 2013 8:33am
ZeDefender
Obvious question... any comparison w.r.t. the Speakers (build/light quality etc.)? Tell someone you love them today because life is short.
Post #206474 29th Jan 2013 8:35am
ericvv
Presume the "They are GREAT" comment refers to the new Nolden, yes?
Same question here, will be interesting to see a full comparison between the Speakers and the Nolden.....
Also the few pictures that I have seen with the Nolden turned on are always with low beam on. How do they look with high beam on? Any pics of that? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #206538 29th Jan 2013 2:53pm
ZeDefender
I believe from an aesthetics point of view "the headlamps are the windows to the soul".
After a lot of work on Photoshop, I'd decided Speaker got it just right with their design before buying.
Solid and practical without looking like a spider or boggle-eyed.
Of the current alternatives, I haven't seen better yet but at least when the Chinese/Taiwanese etc. flood the market the prices will come down... Tell someone you love them today because life is short.
Post #206540 29th Jan 2013 3:13pm
ericvv
ZeDefender wrote:
.....Speaker got it just right with their design...... Solid and practical without looking like a spider or boggle-eyed.
Wot he said..... Thumbs Up
We are on one line Ze Thumbs Up , Speakers will take a wizzard design before they get beaten Whistle You never actually own a Defender. You merely look after it for the next generation.
Post #206544 29th Jan 2013 3:26pm
dgardel
Italy
This new ones seems good like JW Speaker
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #206573 29th Jan 2013 6:41pm
ericvv
[quote="dgardel"]This new ones seems good like JW Speaker quote]
Possibly correct, that's why I would like to see full test, and comparative test results. Seeing is believing Exclamation Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #206581 29th Jan 2013 7:10pm
dgardel
Italy
JWS have 4 years warranty.......
It is very important because the cost....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #206634 29th Jan 2013 9:00pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
The issue for me is not the lights but making them legal with self levellers and washer system. Does an E marked system mean they are legal for use in the UK and an MOT pass?
Post #206639 29th Jan 2013 9:15pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Is the levelling and washers not for HID's rather than LED headlights?
Post #206642 29th Jan 2013 9:20pm
dgardel
Italy
JWS (I do not know about the others makers) have the same homologation than the LR original, so, YOU DO NOT NEED SELF LEVELLING SYSTEM NOR WASHING JET......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #206647 29th Jan 2013 9:25pm
Welshsurferdude
Wales
The noldrum ones have a ECE mark so does thAt make em legal for UK? 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #206652 29th Jan 2013 9:29pm
dgardel
Italy
Yes but we need to know how ECE homologation they are, I think the R112 like JWS..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #206657 29th Jan 2013 9:32pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
They should be legal without self levelling and cleaning as like the JW speaker units, they are under the 2000 lumen limit, however, I'm still waiting on dft to formally confirm this. The manufacturer building to ECE R112 means nothing as non filament bulbs are illegal for retrofit in UK under current UK vehicle lighting regulations. Dft only defers to European type approval in new cars and only provides a formal exemption for HID if fitted to their guidelines.
The 2000 lumen limit mentioned by Tim in earlier post and mentioned in this formal response from VOSA, also seems to provide an exemption for any units like JW Speaker and any other that are under this limit. Just a shame that dft haven't formally replied yet. However, response from VOSA does support that 2000 limit exists, so I would suggest you'd be safe that they are ok and legal.
Steve
Date: 27 December 2012 13:53:12 GMT
To: s******@gmail.com
Subject: Re: Retro fit LED headlamps without self levelling and washers
Dear Mr. G******
Thank you for your email enquiry dated 20th December 2012, concerning the
above.
VOSA can only comment on the MOT scheme.
HiD and LED headlamp levelling and washing systems will only be tested
where they are fitted. If they are found to be inoperative or otherwise
obviously defective they will fail. In the case of headlamp levelling, the
tester must be certain that the system is operative before failing, as on
some of these systems it is not possible to readily determine that they
work as intended.
The reason the test is this way is because not all HiD headlamps are
legally required to be fitted with these systems. To be mandatory, the
headlamp has to be over 2000 lumen. Generally, it is not possible for an
MOT tester to determine whether this is the case, so the test is
'simplified' to take account of this.
DfT produce a factsheet on aftermarket HiD headlamps at
http://webarchive.nationalarchives.gov.uk/...dlamps.pdf
although this does not mention the 2000 lumen requirement.
If you have any further queries regarding the legality of these lights, you
should contact the Department for Transport at ww.gov.uk/dft and select
"Department for Transport" as the section to which you wish to address your
query.
I hope this information has assisted you with your enquiry, but if you have
any further questions please do not hesitate to contact us again.
Kind Regards,
Stephen
Customer Service Centre
VOSA Operations Directorate
Tel: 0300 123 9000
The staff at the VOSA Customer Service Centre are keen to hear your
feedback on the service that they provide for you. This will enable us to
further understand customer requirements and make improvements where
possible. Please take a few moments to complete our Customer Service
Centre Customer Feedback form by clicking here
Stay informed: Sign up for free email alerts and newsletters from VOSA
Direct.
Post #206687 29th Jan 2013 10:25pm
ericvv
Before someone says that this is Off Topic , I comment here about the 2000 lumen cut-off for self-levelling and washers Whistle
Contrary to what has often been said here, I can confirm that not all HID lamps need self-levelling and washers. Proof is our VW New Beetle which here in Switzerland came ex factory with HID lights (factory option), and does not have self-levelling at all. We have washers, but that is only because I ticked that option box at the time, which had nothing to do with the Xenon option box..... One could order the Xenons without the washers too at the time (2004).
I have no idea about the exact lumens of those Xenons on this vehicle, only know they are as bright as any Xenon lights on other vehicles, only difference being that they are "single" Xenons, not Bi-Xenons like usually is the case.
So only explanation I can think of is that they must have remained under the 2000 lumen mark for not needing self-levelling and washers. You never actually own a Defender. You merely look after it for the next generation.
Post #206717 30th Jan 2013 6:42am
Page 3 of 4 <1234>
