Home > Technical > turbo actuator rod |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
hi,
I'm sure I recall reading somewhere about the actuator arm moving freely? I presume this isn't true cos when I've tried moving mine it doesn't budge.....yet I know it works (hopefully as it should)? Presumably you can't move it while the enginer is off.....in that case how can you check that it does move freely etc? |
26th Jan 2013 1:26pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
You won't be able to move the rod up and down due to the modulator. The actuator rod is mounted onto two ball joints, one on the vane arm and the other onto the modulator. The bar will move and feel loose due to the way it is fitted and the joints should be well greased.
26th Jan 2013 7:03pm |
The Puma uses a modulator to move the vane arm. The Td5 uses a wastegate and you can test that with a pair of mole grips. |
27th Jan 2013 11:22am |
