![]() | Home > Maintenance & Modifications > Steering wheel column casing - put Puma one on TD5? |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Same up to chassis number DA431464
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17691 ![]() ![]() ![]() |
The one on my '07 Puma even has the hole for the Series III 2286cc petrol engine choke cable!
which is the 2.2 Simon ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
The casings are identical on TD5's and Pumas, it's an optical illusion because the dash in a Puma comes further forward and covers more of it. You sit in the same position relative to both steering columns as well ....
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I was bruising my inner knees on the TD5. Doesn't happen with my Puma.
Did it have seat risers fitted ?
NOt as far as I know. Had a rear bulkhead (I would remove if bought the 110) Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Did you get to the bottom of this ?
I was intrigued after reading your post and as I have a 300TDi, TD5, 50th V8 and a Puma I took basic measurements of all four and they are all identical. Identical seat box position in 90's and 130's (dont have a 110 currently), identical steering column casings, identical distance between column and bulkhead ???? |
