Home > Technical > Defender interior lamp
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Done a search but can't find the answer.
The interior lamp seems to be brighter in some Defenders and not others. I have recently installed a new bulb, which has actually made a bit of difference but not alot.
I noticed down the local Halfords motor factors they sell a 5w and 7w version of the interior bulb. As I replaced like for like mine is still a 5W one,
Are others fitted with 7w bulbs ?
Thanks
Peter
Post #203740 20th Jan 2013 9:58pm
Tiger
LED is your friend, mines like Blackpool
Post #203745 20th Jan 2013 10:06pm
Lorryman100
I fitted LED lamps to both the internal lights, very bright. Thumbs Up
http://www.ebay.co.uk/itm/48-LED-1210-3528...35c2351cfa
Plenty of choice here:
http://www.ebay.co.uk/sch/i.html?_trksid=p...;_from=R40
Post #203748 20th Jan 2013 10:11pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Try MUD they do one or there's plenty on ebay once you've seen what to look for Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #203749 20th Jan 2013 10:11pm
Gunner
I wouldn't bother using Mud-UK for an LED interior light.
As has been said eBay has loads of choices available and most are just a fraction of the £18.00 MudStuff are charging.
Unfortunately I can't remember who I used but I got two with 20 LED's each from a UK seller for much less than half the Mudstuff price for one.
Fitting couldn't be simpler and the difference they make is far superior to a standard bulb.
Post #203862 21st Jan 2013 3:08pm
geobloke
Likewise... is like turning on the sun...
Post #203881 21st Jan 2013 4:04pm
careful with higher wattage filament bulbs, they could get hot enough to melt the light unit
LEDs must be the best way to go, low heat, low energy Thumbs Up
Post #203905 21st Jan 2013 4:50pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
5 Watt ??
Mine had 10 watt as OE fit [but fitted with LED now] Cool Guns and Landrovers .... anything else is irrelevant.
Post #204028 21st Jan 2013 8:13pm
Peter
In my other 90 I fitted Fluorescent triple tube caravan lamps front and rear, which is much brighter than LED and has better light spread.
But in this instance just wanted to fit a better bulb. I have never found LED's terribly reliable.(Before CREE bulbs)
So if they are 10w, will change it to that.
Thanks
Peter
Post #204163 22nd Jan 2013 1:08am
Peter
I tend to agree but their not all bad. I find the cheaper the LED's are the less likely they'll be any good. The standard bulbs are IIRC 36mm 10w festoon as I replaced mine just the other day with 38mm LED's although they do fit it is slightly larger.
I'd also steer clear of E-bay for any bulbs and use somewhere like Auto Bulbs Direct.
Thumbs Up $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #204277 22nd Jan 2013 12:30pm
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Give Ian at Bolt On Bits a call and he will sort you out with some quality LED's Thumbs Up
Bolt On Bits 01274 688388 Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #204611 23rd Jan 2013 10:06am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Dave-H wrote:
5 Watt ??
I remembered it was 10W on a Td5 and the 10AS will switch a total of 20W to ground.
So i have 10W in the front, 5W in the middle and 5W at the tail door and a 1W LED strip on the tail door itself. 6yrs on, they all are still working. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #205260 25th Jan 2013 4:54pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I fitted a pair of the above ebay specials today.. WOW... Massive improvement over the standard 10w festoon bulbs.. At £3.10 for a pair, delivered from Hong Kong, not a bad investment! Very Happy Very Happy Very Happy ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #209365 7th Feb 2013 11:04pm
ericvv
Post #209367 7th Feb 2013 11:09pm
Killer90
Site Sponsor
ericvv wrote:
Shocked Cannot believe you would have missed this recent thread on that very subject Shocked
http://www.defender2.net/forum/topic17982.html
Thumbs Up i think it was at the top of the new posts everytime i logged on Laughing Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #209368 7th Feb 2013 11:12pm
