![]() | Home > Technical > Defender interior lamp |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
LED is your friend, mines like Blackpool
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I fitted LED lamps to both the internal lights, very bright.
![]() http://www.ebay.co.uk/itm/48-LED-1210-3528...35c2351cfa Plenty of choice here: http://www.ebay.co.uk/sch/i.html?_trksid=p...;_from=R40 |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Try MUD they do one or there's plenty on ebay once you've seen what to look for
![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Gunner Member Since: 31 Dec 2010 Location: Oxfordshire Posts: 6 ![]() |
I wouldn't bother using Mud-UK for an LED interior light.
As has been said eBay has loads of choices available and most are just a fraction of the £18.00 MudStuff are charging. Unfortunately I can't remember who I used but I got two with 20 LED's each from a UK seller for much less than half the Mudstuff price for one. Fitting couldn't be simpler and the difference they make is far superior to a standard bulb. |
Likewise... is like turning on the sun... |
careful with higher wattage filament bulbs, they could get hot enough to melt the light unit
LEDs must be the best way to go, low heat, low energy ![]() |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
5 Watt ??
Mine had 10 watt as OE fit [but fitted with LED now] ![]() |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 ![]() ![]() ![]() |
In my other 90 I fitted Fluorescent triple tube caravan lamps front and rear, which is much brighter than LED and has better light spread.
But in this instance just wanted to fit a better bulb. I have never found LED's terribly reliable.(Before CREE bulbs) So if they are 10w, will change it to that. Thanks Peter |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
I tend to agree but their not all bad. I find the cheaper the LED's are the less likely they'll be any good. The standard bulbs are IIRC 36mm 10w festoon as I replaced mine just the other day with 38mm LED's although they do fit it is slightly larger. I'd also steer clear of E-bay for any bulbs and use somewhere like Auto Bulbs Direct. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 831 ![]() ![]() ![]() |
Give Ian at Bolt On Bits a call and he will sort you out with some quality LED's
![]() Bolt On Bits 01274 688388 Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
I remembered it was 10W on a Td5 and the 10AS will switch a total of 20W to ground. So i have 10W in the front, 5W in the middle and 5W at the tail door and a 1W LED strip on the tail door itself. 6yrs on, they all are still working. The defender has migrated, leaving the owner behind. |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I fitted a pair of the above ebay specials today.. WOW... Massive improvement over the standard 10w festoon bulbs.. At £3.10 for a pair, delivered from Hong Kong, not a bad investment! ![]() ![]() ![]() .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
![]() ![]() http://www.defender2.net/forum/topic17982.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
