Home > Technical > Trying to understand the gear stick rattle |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
yeah its the weights that rattle, mine did until i put some superglue round them NO ROAD..........EXCEPT FOR LANDROVER
24th Jan 2013 7:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20355 |
Mine rattles too but only really in 6th gear. I would have rectified it myself but due to lack of info on what to actually do with it to rectify the problem I have just lived with it. Would like to sort it if it's not too much of a faff so when people mention "glued the weights" that's pretty easy to understand but identifying what to actually do with it is a different matter. I assume they just vibrate against themselves / something and that causes the rattle noise? $W33T $0U7H3RN $UG4R
24th Jan 2013 7:40pm |
Moggy Member Since: 02 Oct 2011 Location: Suffolk Posts: 83 |
trying to understand how they make a metallic rattle when encased in plastic and why the lever is floppy !!!
Cheers 61 plate-110 USW......a bit pimped 54 plate NAS Spec 90-sold 4-Defenders-sold |
24th Jan 2013 7:41pm |
Click image to enlarge i just sploged the glue to the weight where it touches the plastic holder, it seemed to cure the rattle 8) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated NO ROAD..........EXCEPT FOR LANDROVER |
24th Jan 2013 7:43pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
My gear stick rattled when warm after about 50 miles on motorway. Cured by removing stick and using nylon cable ties to jam weights in place. Was told it was due to the plastic and metal expanding at different rates when heated. Noroblems since. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
24th Jan 2013 7:48pm |
What purpose are the weights meant to serve in the first place? Other than being a PITA $W33T $0U7H3RN $UG4R
24th Jan 2013 7:51pm |
i think they make for an easier gear shift, or maybe helpful if using the gear stick for self defense?! NO ROAD..........EXCEPT FOR LANDROVER
24th Jan 2013 7:52pm |
The gear stick is plastic, hence light in weight. The weights are there to make it bottom heavy and so vibrate less. Most cars have very short gear sticks unlike the Defender. Anyway, that is my theory. LANDYWATCH
24th Jan 2013 9:03pm |
Instead it does the opposite. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Jan 2013 9:05pm |
In mine the weights were loose in their carriers when hot. The noise, there was no significant vibration of the gear stick, could be stopped by gently pressing on the base of the stick through the gaiter. LANDYWATCH
24th Jan 2013 9:11pm |
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 |
G'day Lads,
My 90 has developed a 'rattle' when in 5th and 6th gear mostly only when the engine is under load, not when coasting or cruising but put the foot down and it starts. This started at about 9500kms. Its not overly loud but I can hear it and so has the wife, so I guess it is there as she can't hear most other noises . You can alleviate it to some extent by putting pressure on the gear knob either forward or back. Mine isn't metallic though, the best way I can think of to describe it is it sounds like teeth chattering, is this the same sound you guys are referring to. Mick |
25th Jan 2013 9:15am |
It was for me Cracka. Now ALL gone. It started on mine at about 7000 miles BUT only after an extended run when everything had warmed up and it was during warmer weather. LANDYWATCH
25th Jan 2013 1:30pm |
I am concerned as the noise is like 2 metal washers rattling together and the lever is quite floppy. 61 plate-110 USW......a bit pimped
25th Jan 2013 5:51pm |
Thanks WelshGas,
Can you or somebody else enlighten me as to how I go about doing this fix Do I need to remove the complete rubber floor mat around the tunnel or does the rubber gaiter pull up some how? I don't want to go busting and tearing at things blindly. How do I remove the gear stick itself, or do I need to, to complete the fix. Hope you don't mind the questions but it's easier to ask someone who has already done it. Thanks in advance. Mick. |
26th Jan 2013 5:49am |
