Home > Technical > Loose metal noise/rattle when the going gets tough |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
I get something like that on the Puma.Thats were my 90 with a tune v8 make me Silent grunt!!!! Puma 110 SW
90 V8 SOFT TOP |
30th Mar 2011 1:00pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
clutch no 2 for me i think! Mike
30th Mar 2011 4:21pm |
Puma90man Member Since: 27 Feb 2011 Location: South Africa Posts: 26 |
Oops - MSE - How will I be able to confirm if there is a problem with the clutch? |
2nd Apr 2011 7:53am |
All i can tell you is you almost described the noise and conditions i got tha gave me a new clutch (no 2) i think i had 3 in total.
But it all depends on the noise. Mike |
2nd Apr 2011 8:06am |
Stef M Member Since: 21 Mar 2011 Location: Gent Posts: 9 |
I had this same noise, LR thougt it was the clutch... Turned out to be a heat - shield underneath giving this noise.
I just needed to push it into place again and noise gone... |
3rd Apr 2011 10:10am |
Hope its the simple solution for you Mike
3rd Apr 2011 11:33am |
carlaac Member Since: 09 Dec 2010 Location: Hampshire Posts: 58 |
+1 tighten my bolts up again today after. Was about 2 months since I last tightened them and they were nearly falling out. Although I did a straight 14hrs from Alps to home at 70 on the autoroute. Just the right frequency to rattle them loose. |
3rd Apr 2011 9:47pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Could just possibly be the rear brake rattle feature. easy to test, lightly apply the brake with left foot and see if the noise stops.
More likely to be the clutch I think. |
4th Apr 2011 8:42am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 257 |
are you sure it's not the traction control working ?
Dave Dave |
4th Apr 2011 4:07pm |
No definitely not traction control. Sounds more like thin metal plates rattling against eachother. I'll go check the heat shield (just not sure why it only rattles when the vehicle is running out of oomph on steep inclines?) Anyway - any excuse to spend some time under the landy...... |
4th Apr 2011 7:42pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
and.....
19th Jan 2013 9:12pm |
"Thin metal plates rattling against each other".....
Sounds like could be the brake pads against the calipers.... see the link to this thread specifically about that very common problem http://www.defender2.net/forum/topic14339.html?highlight=brakes You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
19th Jan 2013 9:25pm |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 |
Had exactly the same symptom on mine and it was the transfer case touching a steel protection plate that I have fitted as extra. The protection plate was bent a bit in the middle between the chassis beams after some playing on deep snow and rocks.
What about that ? Could also be a failed transfer case mount. Mike. |
22nd Jan 2013 7:52pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
I asked a similar question about a year ago.
When towing the caravan and pulling away in an inappropriately high gear from low speed (say third instead of second) I can hear a clanky rattle that lasts for about a second or two. It too sounds like its coming from the front prop or diff and disappears as speed increases. I was advised that its perfectly normal under load. I haven't towed since last August and my drivetrain is totally clonk free so hopefully its nothing to worry about |
26th Jan 2013 7:41pm |
