Home > Technical > Loose metal noise/rattle when the going gets tough |
HotelCharlie Member Since: 20 Oct 2011 Location: Kavala, Greece Posts: 25 |
On my 110 Puma, I was getting a metal clicking noise on rough trails at any RPM, like metal plates vibrating against each over.
Would drive me crazy, stopping half a dozen time to check what was coming apart, to no avail. Weeks later, while cleaning underneath the engine compartment I banged on the steering damper!! eureka, the outside sleeving tube bangs against the inner tube, so rough trail produce that sickening noise. No harm done, and easily solved with a piece of bike inner tube. <img> |
2nd Feb 2013 6:38pm |
1ten.neuss Member Since: 07 Nov 2008 Location: Neuss Posts: 27 |
This was indeed the case identified by the workshop crew today. Slightly press the break when travelling at a known "rattle road" and the noise is gone. Bernd |
4th Jun 2013 6:14pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2625 |
That's the TC kicking in? best described as a 'twannnng' -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
5th Jun 2013 10:07am |
bvandyk Member Since: 03 Sep 2012 Location: South Africa Posts: 49 |
Sounds like the springs in the clutch pressure plate that is loose. There is a recall out for that.
18th Jun 2013 12:55pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
I have just had this and my wheel bearings needed nipping up. All good now. Rhubarb and custard let fly with their secret weapon.
22nd Jun 2013 11:05am |
