Home > Puma (Tdci) > Could a faulty injector... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Liam
I hope you get sorted. the only advice I can give you is it would appear my heat shield has been causing me a load of grief. Probably nothing to do with your issues but all I can say is for the sake of a few seconds makes sure the whole of the turbo heat shield assembly is secure. good luck |
16th Jan 2013 9:58pm |
Slim Member Since: 08 Jan 2013 Location: Wales Posts: 9 |
Caterham,
During the clutch change the down pipe/cat came off and back on. The bolts are all present and tight. Thanks though! |
16th Jan 2013 10:05pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Injectors can knock badly if faulty
Trouble is you dont know which one it is with out correct test equipment Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
17th Jan 2013 5:14pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
Quick answer is yes - Do you get it at other times ie starting from cold (that was when mine was most noticeable)
17th Jan 2013 5:25pm |
WOOOOOOOOO HOOOOOO! Sorry, can't contain myself!
Short story, No3 and No4 injectors were loose, and bouncing up and down. Tightened them down and all is good. So be aware! Thanks for the tips guys. Let there be snow! |
17th Jan 2013 10:30pm |
Thats worrying but it is a Landrover
Good you sorted it Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
18th Jan 2013 7:12am |
slim,
great news that its sorted. I'm sure I don't have the same problem however I've got to the point that I want to check everything I can. was tightening the injectors as simple as it sounds? |
21st Jan 2013 10:15pm |
Hi Caterham,
Cheers, I'm well pleased. I didn't tighten it myself but I believe that it is one 8mm bolt per 2 injectors. If you remove the plastic cover then it should be obvious. Be careful not to over tighten them though as the head will be made of alloy. Hope you find the root of your problem soon. Cheers. |
22nd Jan 2013 6:34pm |
General Lee Member Since: 09 Feb 2013 Location: Grahamstown Posts: 19 |
On my way to check my injectors........but gents,I have similar noise coming from the engine.But as soon as I engage my clutch(step on the clutch), the engine runs lovely.Engine also seems to run good on a cold start.
20th Feb 2014 6:16am |
should really fit new copper washers on the bottom of injectors and have the injector sets checked , esay to remove injectors . if seats are damaged you may need I seat cleaner its like a long reamer bit like a water tap washer reamer .only needs normally a couple of turns to get good seat back .
if there blowing they can build up carbon under the washer and will never seal 100% just by tighten down if there quite loose you get misfire or not so loose a chuffing sound and smoke from oil filler cap as puma washers are internal |
20th Feb 2014 9:11am |
Tumich Member Since: 09 Apr 2013 Location: Prague Posts: 9 |
ON the early MOdels 2007-08 were the Clutch plates or sth there bad made
so when its when the clutch is on than it could be this |
20th Feb 2014 3:15pm |
