Home > Maintenance & Modifications > Puma 2,4 Engine upgrade
Page 3 of 3 <123
bell-auto-services
Personally unless the car is tuned within an inch of its life and is not used for what would be classed as normal driving id lease it alone. I have found that a centre cylincer removal but with a small box in and some air box modifications will give a better gain that the decat does.
Pete
Post #201987 15th Jan 2013 11:35am
BruceT
South Africa
And the heat issue? "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #201988 15th Jan 2013 11:38am
bell-auto-services
I didnt measure cabin heat on the 2 setups.
pete
Post #201989 15th Jan 2013 11:46am
BruceT
South Africa
Thanks Pete "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #201990 15th Jan 2013 11:49am
jst
Pete, can you shed some light on the air box mod? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #201993 15th Jan 2013 11:51am
Naks
One thing that Pete is not aware of is how bad our diesel is.
IIRC, diesel in the UK is <10ppm?
We are still on 500ppm with 50ppm in major cities only, so that's a factor to consider --
Post #202030 15th Jan 2013 1:52pm
pepekleinhans
South Africa
Pete
Very Interesting Pete, you have made alot of us thinking now, and also re-thing of our plans. Shocked
Thank you very much for the info
Pepe 2005 Discovery 3 HSE
2007 2.4 Puma Defender
1976 series 3 with Ford V6 engine
Post #202043 15th Jan 2013 2:48pm
pannawonica
Australia
The heat issue is considerable, I cannot bear my hand on the back of the seat box when travelling to the shops, this was only on a 47C day. Very Happy
Post #202270 16th Jan 2013 1:36am
BruceT
South Africa
Laughing yes we get those temps in some areas in Southern Africa also so I can relate. Even the aircon stops working. This is the main reason I would like to do a decat. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #202274 16th Jan 2013 5:33am
pannawonica
Australia
I plan while I'm at the decat to lag the downpipe and centre box replacement. However I have read somewhere that stainless does not like to lagged and that it cracks, mild steel lagged, corrodes at a increased rate.
Post #202286 16th Jan 2013 8:45am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Lagging would retain heat. What about an insulated heat shield between exhaust and underside Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #202384 16th Jan 2013 5:36pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
I removed my cat about two years ago and have had no problems whatsoever. Living in a hot country, as I do, it made a huge difference not only to cabin temperatures but also reduced the engine temp as well.
When I contacted BAS asking if I could get one of his tunes and upgraded turbo's and I explained what I had done to the 90, I received a rather dismissive email back telling me that I had should never have removed the CAT and asked "who told you to do that?" The tone of the email was not impressive, needless to say someone else got my business.
Post #202411 16th Jan 2013 6:49pm
pannawonica
Australia
[quote="pope10001"]I removed my cat about two years ago and have had no problems whatsoever. Living in a hot country, as I do, it made a huge difference not only to cabin temperatures but also reduced the engine temp as well.
This is the result that I'm hoping for, when you consider how the Cat works by absorbing heat this would be the expectation. Hold one up to the light and you cannot see through them, not good for gas flow and heat removal ! Thumbs Up
Post #202523 17th Jan 2013 9:12am
Page 3 of 3 <123
